Looking for help and guidance please..
A USCG inspection of my 25 Seacraft (2001) found that I am lacking a "certificate of compliance" since their regs state that any boat built after 8/1/1978 and having a "closed fuel tank compartment" must display a "certificate of compliance". I was told this is the same thing as the standard mfg's. placard which confirms max passenger capacity etc. I could not find any such placard on my boat and the boat has not been rebuilt. Can anyone confirm where this placard would normally be found (suspect somewhere on the console), or where I could go to obtain the placard ("cert. of compliance" for my particular model. Thanks to all who might be able to help on this, since the C.G. stated that they may make the boat stay in port without it. G.R. |
Thanks for the tip Ken,
Unfortunately I poured thru e-Bay to no avail. This is a little disconcerting for me and perhaps should be for other post 8/1/78 built boat owners with closed fuel tank compartments. Again, I was told today by a USCG inspector that a boat without the compliance placard from the mfg. on display is in violation and subject to a "return to port order". My guess is that hundreds, if not more, boats like rebuilt and non rebuilt Seacrafts like mine simply don't or no longer have the compliance placard. This issue of course is not limited to just Seacraft. I don't know if this might have insurance implications and wouldn't want to find out the hard way. So, I am still wondering if there is a place to get the placard. Is there a Seacraft support center anywhere that could assist with getting the model placard issued? Any help (or comments) would be most appreciated. Geoff Reuland |
OK Ken,
I see where they are in essence, custom made... Geoff |
Geoff,
Half of these Gov. morons have no clue what the law really is.... Just get the Cap sticker made and be done with it.. I have been through the same chit with my 1970 SF.. No hull ID on my ole' vessel as well ! Just play the game and smile... Later.. ![]()
See ya, Ken © |
FWIW here is the capacity sticker for my '76 Seafari in case someone wants to duplicate it. It is located under the helm. It reads:
Max HP 175 Max weight capacity in persons 900 lbs Max weight capacity persons, motor and gear 1162 lbs Guessing my Merc 150 tower of power weighed about 300#, bet we frequently exceeded 1162#, with the skis, coolers, gear, etc. Not to mention those boats loaded up for multiday trips. My current ETEC 150 is 418#. |
https://www.usps.org/national/vsc/fo...iles/a7012.pdf
The Cert of compliance is not required. The link above is the coast guard (VSC) Vessel Safety Checklist. Both are under "Recommended and Discussion Items". Under 20' the capacity placard is required by federal law. Under 26' it is required by NMMA for the MANUFACTURER to install the plate to be part of the NMMA... on a 23' boat there is no requirement for you to have a capacity placard. I wouldn't worry about it. |
Trophy shop.
My `89 20 is rated for 235 and they don't blink an eye. Placard says nothing about fuel tank. I believe that is only for IB and IO power. My factory placard states O/B model. |
Hi Geoff,
I thought the regulations specified only boats 20' and UNDER are required to have capacity plates... Pretty sure thats the case. Or at least it was. Maybe the regulation has changed?
Zachary [SIGPIC][/SIGPIC] |
