I'm getting ready to pull up the foor in my '78 23cc. It's been sitting for a number of years and the motor is shot. So while I've got the deck up I want to take a good look at the tank. Any chance it's still good? Do I have to remove it to properly inspect?
You won’t be able to inspect the bottom and that’s most likely were there would be corrosion . since your in there I would pull it and clean it inside and check sender. Get it all checked and done so you don’t have to go back there
To answer your questions....1. slim chance, if it's original very slim chance, 2. Yes sorry gotta remove it, getting it out that's the tough part.
There are some post of guys building a wood rack or tripod kinda thing over the tank to lift it out with come along.
Unfortunately, opening up the hatch is a whole new world. How it all started for me. Hatch needed to be recored. All fuel lines upgraded to new methanol standards ($10/‘). The “$10/gallon” rule of thumb seems to be of the Baby Boomer era, especially with new tariffs on the aluminum. Go at least .125 thickness over standard 0.90 (should in theory last longer). The foam around tank will reflect where water held and corroded tank worse than where foam was not in contact with aluminum. Cut it out using a sawsall, but be careful determining if there is a floor in the hold. My ‘79 20 had beautiful gel coat finish inside. Be careful. Otherwise, not a bad job. As said, triple your time, money and beer budget. Or BOAT: Bring Out Another Thousand. A pic may help you see how to raise, pitch console out of the way without disconnecting or removing. Hope this helps.
Vezo Oh and the Coal Tar Epoxy |
Two best suppliers should be RDS aluminum, Perry, Florida or Sunshine Tanks of South Florida, original builder of Potter era SeaCrafts.
Vezo. |
Maybe 12 years ago I ordered a tank from RDS made to my drawing duplicating the original dimensions. Looked good and have been satisfied. However discovered the bottom had some downward bow to it due to weldng distortion. I ground down any high spots where it would sit. But also had to grind the access hatch to avoid interference with the fuel fill elbow. Also put a rubber strip around the hatch to raise it slightly. Maybe should have requested a smaller height dimension. Just FYI
Agreed. Once you send them the measurements, they develop a mechanical drawing, including fitting locations, email it back to confirm specifications. Once you sign in agreement, they’re building it and you’re paying for it same with Sunset, I believe, but they have specific drawings for you to approve.
Vezo. IIRC... |
The 49 gallon tank (47 gallons usable) for my '88 18' retails for about $830. It was a bit less with my West Marine Associate discount.
