Old 04-14-2003, 12:43 AM
Default Seadog back on the water!
I've seatrailed over the past few weeks, and I'm proud to say another Seacraft refit has successfully been performed. Tramsom replaced and totally closed in, B-Bracket installed (slight modification after initial seatrial), Suzuki 140 4-stroke for power (44 mph top speed w/ quite a good hole shot!),replaced leaking 50 gals fuel tank with new 60 gals tank, hull painted "Fighting Lady Yellow", and completely rewired.
I can't describe the joy of taking one of the guys for a ride down the Banana River after 4 months of hard work (and the look on thier faces 4 months ago when I started this madness).
I still have some loose ends to tie up, and I let some of the costmetics slide, but I'll be fishing by May!
As always, tell me how, and I'll send you pics.
Lloyd
Old 04-14-2003, 10:42 AM
Briguy Briguy is offline
Default Re: Seadog back on the water!
CaptLLoyd,
Do you have and 18' or 20'? How do you like the B-Bracket? Is the bracket a flotation model and if so, did it provide enough bouancy?
Thanks.
Capt. Brian
Old 04-14-2003, 11:22 AM
TUGBOAT TUGBOAT is offline
Sounds like a 20 MA ?I could sure USE a HAND on the RE-Wire,!!!!!!!!!! Keys sure are Beautiful right now !!Although its too late now !I really wanted a bb on Mine .PLEASE TELL ME IT IS NOOOO GOOOOD !!!!!!!
Scream'n Reels'
C.Brad [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 04-14-2003, 11:45 PM
Briguy,
It's a 20' and let me say I'm thrilled with having a B-Bracket on the boat, the versiatility it provides is fanatastic. But the B-Bracket's floatation is just barely adequate. With the new motor's added weight and distance aft, I've added an extra 1" of draught. And I did have to add a wedge, which I fabricated out of starboard, to the bottom of the floatation chamber to eliminate the motor being drowned while coming up on plane(all things seems fine once on plane). I talked to the guys from B-Bracket about my problem, but they seemed clueless about my situation, so I designed my solution on my own, and I got lucky on my first try. I'll send pics when I can.
Capt Brad,
Wiring jobs can be big, or small, pretty, or ugly, all depending on your tools, supplies, and patients. I'm very busy for the next 3 weeks, but a road trip after that could include a "snake", "T-strippers", crimpers, and heat shrink. Keep me posted if help is needed, it well cost you a few beers and a boat ride.
Lloyd
Old 04-15-2003, 01:35 AM
SECF3114M73J SECF3114M73J is offline
A friend of mine has a B-Bracket on a-I think-'71 20 fter. He has a 135 Merc. He had to add about 100 lbs. of ballast up in the bow.
Old 04-15-2003, 07:35 PM
JohnS JohnS is offline
Lloyd,
I had that same problem when I first got mine with the bracket. I installed trim tabs and, even though it may sound a bit off base, they worked great and fixed that problem with the motor getting drowned, both while getting up on plane and when coming to rest. I used the Bennett Sport Tabs and I can honestly say they were great!!!
John
John
I support the "Hot Boat = Hot Chick" theory.
