Hello!
I bought a 1970 20' CC back in April. It is an I/O and was advertised as a "Potter hull." It's first shakedown cruise is planned for this Saturday, weather permitting. I'm new to boat ownership, so I'm getting a lot of advice from my boat-owning friends and relatives. Still, none of them own SeaCrafts, so I figured I'd see what the folks here have to say. The boat looks great. The previous owner (second owner) repainted with imron paint. He put new rub rails, a tee top, leaning post, and some electronics on the boat. He got an aluminum Float On trailer when he boat it. It appears he worried about the looks more than the mechanics. My buddy and I (mostly him) pulled the engine and after a new manifold and riser and misc. pieces got it purring fine. The gimbal bearing was just replaced with everything that goes with it. Now the outdrive comes into question. The Professional mechanic seems to think it got water in it at some point. We will run it this weekend (with another boat following)and then change to oil in the outdrive to check for color and metal pieces. Any advice for a new owner? How about suggestions on replacing or rebuilding outdrives? I'll try to get some pictures this weekend to post. Thanks! |
BaneDog
Welcome Aboard !! Just come w/ plenty of ?'s & Beer !! Oh There's a lot of THEORY's Here !! I'd rather Buy a Boat that was Kept up (LOOKS) As long as the transom,deck,etc.Was in great shape than Mech. Only because its easier for Me to get that work done. ENJOY ! Good luck on the Sea Trial !! Scream'n Reels' [img]images/icons/cool.gif[/img]
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Welcome and enjoy the voyage this weekend. Good idea to drain the lower unit and check for water intrusion. Unless the outdrive is shot, the only thing you might have to rebuild is the lower unit, which, if your mechanic is pretty good, is basic and simple for the most part. If you do need to rebuild because of a leak, that is simply the seals and possibly a few roller bearing. Unless corrosion set in on the other parts or it was really abused, than it should be easy. Some snap ring pliers will be a must but not much else in the way of special tools. A kit with all the seals is available. Last time I did one, it took me a couple of hours to do. I also sanded, primed, and repainted while it was off because it was much easier than doing it while on the boat. Just a thought if it needs it. Check the prop shaft for staightness too, as long as you are at it. This will tell you pretty quick if someone, at some time, smacked something REALLY hard with the prop. That is one of the major causes of seal leakage.....
[ June 19, 2003, 12:59 PM: Message edited by: JohnS ]
John I support the "Hot Boat = Hot Chick" theory. |
Thanks for the words of wisdom. We had the engine out and the transom was dry. It really is a beautiful boat. I'm climbing the walls until Saturday. Too much rain to do much outside until then. I'll probably think about replacing the console in the not too distant future.
Here's some interesting history on the boat. The guy I bought it from, bought it in Miami from a guy named Ricky. Apparently Ricky fished with "some guy named Jose." The story goes that Jose got his "pro status" while using this boat. The implication was that perhaps it was Jose of Spanish Fly fame. No idea if it's true or not. It certainly was not a factor is buying the boat. Still, a good story is a good story. |
I'm in the same boat as you (almost exactly) [img]images/icons/grin.gif[/img]
Are you posting on the Tidalfish website as well? Good luck with that yell'r boat if you're the same guy!
The artist formally known as duskydan... Old Yeller 21 Sea Craft-200 Merc Parrish Creek/West River http://www.imagestation.com/picture/...2/fc3ef46d.jpg |
Just for the record..It IS a Potter hull. [img]images/icons/grin.gif[/img]
Ted |
