Old 03-26-2002, 08:00 PM
Capt Skip Capt Skip is offline
Default Need Ideas
Does anyone else have an inboard were the whole console hinges forward to recveal the motor? What type of hinges do you have and how many people does it take to tilt it? Any thoughts on haveing it electricall lifted?
Lastly how can I gasket the in floor box in front of the console. That box collects so much water. I am adding a fitting to drain it through the rear bilge pump but must be some way to slow the water accumalation down.
Capt. Skip Slomski
Jennybeck Charters
410-746-6907
Old 03-27-2002, 12:45 PM
Scott Scott is offline
Default Re: Need Ideas
Capt. Skip
Bennett makes hydraulic lifts for that application. I would check that out so you dont screw up the back trying to get that thing open...
I believe you can even use your existing hydraulic unit (if you have Bennett tabs) to operate this one......naturally you would only have the tabs working while underway and the hatch rams working while at the dock....
Tabman is this true???
http://www.bennetttrimtabs.com/hatchlift.htm
Scott
[ March 27, 2002, 11:48 AM: Message edited by: Scott ]
Old 03-27-2002, 05:54 PM
Frank Frank is offline
Skip, I would use nothing but some heavy Stainless hinges on that console. I believe Contender uses an electric lift on the front of there cosole on the 25'. Those lift the front forward and up for access to the inside of the console. I'm not to sure but I think the new 25 Seacraft has something similar to open up the fron of its console. Maybe one of those unit could be adapted to raise your console. By the way, I'll be down in Sebatian Inlet, Fl starting tomorrow and all of next week doing a little fishing and R&R. So if you shout, I'll talk back next week when I get back.
