Old 11-24-2003, 09:48 PM
John R John R is offline
Default Respirator
For working with various epoxies / West System et al, what king of respirator / style / brand do you guys recommend (and cheap links [img]images/icons/grin.gif[/img] ) ...
Thanks,
John
Surf and Boat fishing for
Striped Bass
Old 11-24-2003, 10:15 PM
EBEACH EBEACH is offline
Default Re: Respirator
John, I bought mine at HD for about $30-35. It is a 3M brand. just make sure it is good for vapors, not just dust alone. Don't think you'll need it with epoxy. Polyester for sure and any sanding and finishing work.
I wore that thing for hours on end, and day after day.
Old 11-25-2003, 01:50 AM
Scott Scott is offline
John ...3M 6000 Series respirators
I've not used these guys ....but I may get a full face from them .... The half face (which I do have) looks to be about $22 ( $10 for the half face, $2-3 for the particulate filter, $7-8 for the OV cartridges and $2-3 for the retainers....West marine sells it for $40.00
This is the same ..rather.. an updated respirator that I used at work in the Pharmaceutical plant ...
Great respirator for OV (organic vapor) and dust... like Jim says you shouldn’t have a problem (well don’t forget what happened to Otto) with epoxy resins but definitely need it for poly or vinylester resins vapors.
Word of advice ... If your going to be doing A LOT of grinding you may want to consider a full face ... I have just started to recover from fiberglass grindings/dust in my eye..from mid October..Trust me it was not a good thing ..I'm still suffering from blurred vision in that eye..AND YES I even had goggles on, but the dust found its way in through the vents in the goggles...grinding on windy days is rough [img]images/icons/frown.gif[/img]
Old 11-25-2003, 10:03 AM
A full face is OK with me. But will these "organic" filters be sufficient for the chemical vapors?
Striped Bass
Old 11-25-2003, 10:14 AM
Billybob Billybob is offline
John- The OV cartridge respirators are good for epoxy and poly resin.But don't spray any 2 part paints with them, you really should have an air supply respirator if you're gonna do that.
There's this cute little kid on one of the New England fishing sites that really deserves to have a healthy dad around to learn him some fishin. [img]images/icons/wink.gif[/img]
Old 11-25-2003, 10:53 AM
As Bill says...No problem with what you will most likely use for the project...anything nasty you use SHOULD have an MSDS (safety sheet) with it telling you what you need to do to protect yourself.
A question ....I know what I've been told so I think I have the answer for it but... Roll and Tipping a 2 part with the OV respirator is acceptable ...yes or no ???
