Old 12-30-2003, 12:33 PM
seahaag seahaag is offline
Default Fuel tank size on 1986 23 outboard
I picked up a 23 outoboard and ran it this summer. I had problems fueling it up. Could never tell if tank was truly full. Gauge is obvioiusly off. I was told it holds 125 gallons but not sure and don't like spilling fuel or running out as means to the answer. Anyone have an '86 or know the answer. Thanks
Larry Haag
Old 12-30-2003, 02:47 PM
ocuyler ocuyler is offline
Default Re: Fuel tank size on 1986 23 outboard
Larry,
Welcome to the site. I have an '89 23 CC w/ 200 Yamaha. I replaced the tank this spring with 133 gal. aluminium from sptanks.com. They built to my specs and coated with epoxy. Nice tank. Included an electric sending unit installed.
My tank was foamed in and had several small leaks where the foam was touching. The fill tube was cracked and leaking as well.
Otto
Old 12-30-2003, 02:54 PM
Scott Scott is offline
Length x width x height / 231 = volume in gallons
(Measurements in inches)
Old 12-30-2003, 02:55 PM
Otto
Old 12-30-2003, 03:10 PM
The new tank is roughly 28" wide x 11" high x 116" long outside. If I did it again, I'd make it smaller and shim it in for better air flow.
Otto
Old 12-30-2003, 03:37 PM
ScottM ScottM is offline
Dieter Sprockets
Using Scott's formula, Otto's tank comes out to 154.66 gallons [img]images/icons/confused.gif[/img] .
