Old 11-20-2002, 08:11 AM
Tom Bare Tom Bare is offline
Default cleaning hull... help fast!!!
Hey guys, what's the best way to clean a long neglected hull? Simple compound and wax? Are there products out there that work better than others? I gotta' guy with a buffing machine in his hands waiting for instruction! Want to get him started before he realizes what he's in for and changes his mind!
Thanks,
Tom Bare.
Old 11-20-2002, 09:04 AM
Runco Runco is offline
Default Re: cleaning hull... help fast!!!
Wet sand with 600 or 800 and then polishing compound until no scratch marks. Then wax,wax,wax until like new!
Old 11-20-2002, 09:18 AM
JohnB JohnB is offline
I used 3M marine rubbing compound for heavily oxidized fiberglass, then used 3M wax/restorer. If you are using a machine, kept the surface wet with compound so you dont burn it. Then I used wax.
JohnB / 23' SeaCraft
Old 11-20-2002, 11:47 AM
squidrig squidrig is offline
Try FSR...the stuff is incredible. West Marine carries it.
Mish'n Fish'n
Old 11-20-2002, 12:14 PM
Matt1121 Matt1121 is offline
Tom-
I use a water-downed version of 3M fiberglass rubbing compound . Try that first and be sure to keep the buffing pad wet with the product. Once you're done with the compound, follow-up with Starbright's Teflon marine polish ( you'll need to put on 2 coats about a week or two apart). Stuff is expensive $20, but is well worth it..I use it on my truck too.
If that doesn't work, break out the really fine wetsand paper that someone else mentioned previously. Be ready to sand until your arm falls off.
Old 11-20-2002, 12:15 PM
Tom-
