Old 11-25-2002, 05:00 PM
catman115 catman115 is offline
Default battery placement
On my 20' seafari the battery is located in the starboard corner of the boat. I would like to relocate the battery inside the cabin forward of the control bulkhead.I'm a little worried about the movement of the hull when I happen to crest a wave or two. Would the acid splash out of the vent holes ??. Where do you center console boys have your juice mounted. There is a little built in storage area that would be perfect. All of this would just make it easier to install a larger battery than a standard group 24.
Old 11-25-2002, 05:17 PM
PressureDrop PressureDrop is offline
Default Re: battery placement
catman - i have the same boat, ill be moving the batterys from the back center into the cabin, they will eather be one on each side of the cabin infront of the bulkheads, or on the cabin floor where a porta potty would go, and ill build a nice cubby for them.
Ben
no falls, no balls
Old 11-25-2002, 06:09 PM
BacDoc BacDoc is offline
I have mine (2 batteries with perko switch)on the floor under the center console on my 20'. It's easy to get to and keeps the weight forward and allows use of any size battery.
Old 11-26-2002, 07:53 AM
bmaj319 bmaj319 is offline
I have the same setup as BacDoc on my 18'. Works great!
Old 11-26-2002, 09:38 AM
jw jw is offline
I have a 20CC I/O and my battery is in the STB Little seat in the back.
[img]images/icons/grin.gif[/img]
www.bansheecharters.com
Wishn' I was Fishn"!!!!
Old 11-27-2002, 01:01 AM
Mark Mark is offline
My setup-
18CC - 2 batteries in console
20CC - 2 batteries in console
Good luck/
mark
