Old 10-28-2003, 06:03 PM
MKG MKG is offline
Default Twins on a 20' Master Angler
Hi guys,
Just wondering if anyone can shed some light on the possibility of putting twin 90 Fichts on either an armstrong or other flotation bracket on a 20' Master Angler.
I want this 20' that is here but already have a 90' ficht - and can get its twin for cheap!
Dont want a single = too risky here.
Many thanks
Old 10-28-2003, 11:09 PM
Ryan Ryan is offline
Default Re: Twins on a 20' Master Angler
mkg you can hang the twins on there, there were 20 c.c."s factory rigged w/ twin 70hp. but you should consider the bracket and close the transom completely. The only problem is that it can get a little pricey
Old 10-29-2003, 12:04 AM
John R John R is offline
90 Fichts will weight a bit more than 70 carbed rudes from the 70s - one thing to consider. Item 2, the engines back then were flywheel rated and not propshaft so a 70 carb then was probably putting out 55-60 of todays HP... All that said a couple people have mentioned of a 20 with twin V6s somewhere in FL... - Twin 90s would go like a raped ape too,.,,
Surf and Boat fishing for
Striped Bass
Old 10-30-2003, 01:58 AM
TUGBOAT TUGBOAT is offline
Yep That was the Mainstay of the Bahama runners way back ,twin 70's I would be concerned about the bracket then twins hangin on, lotta weight !,(20')
Butt then Go forward Young Man !
Scream'n Reels'#"624"
Welcome aboard !!
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 10-29-2003, 02:34 PM
Briguy Briguy is offline
More than likely you will have to raise the transom by 5 inches if you go to twins. That will help keep some h2o out of the back. Hang them on then HANG ON!
PS. If you don't like the weight afterwords you can put a bracket on.
Capt. Brian
Old 10-29-2003, 03:41 PM
MKG MKG is offline
Thanks guys - i think i am going for the full flotation bracket and then with the twin fichts.
i will also cut out the well in the rear for some more space and enclose the transom if i dont get a hermco bracket
i am assuming the larger the brachet the more flotation etc?
Do the motors need to be counter rotating ?
