Old 11-19-2003, 03:33 PM
Mark Mark is offline
Default we aren't so bad after all
this should be shown to any spouse who thinks that a complete SeaCraft project-boat undertaking is going too far:
http://www.insidesportfishing.com/Ex...age.asp?CLID=1
Old 11-19-2003, 04:13 PM
EBEACH EBEACH is offline
Default Re: we aren't so bad after all
I like this part:
"After filling 24 dumpsters with rotted teak, timbers and deck, we were in so far over our heads that I actually considered Kimberly’s suggestion of renaming the boat Bad Idea. "
Old 11-19-2003, 04:15 PM
is this really where the disease leads? [img]images/icons/shocked.gif[/img]
Old 11-19-2003, 04:50 PM
TUGBOAT TUGBOAT is offline
WHEW !!!!!
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 11-24-2003, 02:42 PM
other tom other tom is offline
Mark; yes. that is exactly where the disease leads. although, this guy has me beat hands-down on the "miles of wiring" he's removed. Very impressive!
Inspecting one of my transmissions revealed a hole in the case (caused by previous owner not fixing a leak in the raw water pump), which meant moving an engine, which meant removing the exhaust, which meant removing the heads, which mean new motor mounts which meant all new fuel/oil lines which meant new battery-engine wiring, which meant moving the watermaker which meant moving the generator, which uncovored a rotted genset deck, which uncovered a leaking rudder post, which also meant new dripless shaft logs (while we were out) which meant replacing 4 seacocks, and while your at it might as well major the engine, and install new scoop strainers for main intakes, which meant that you found cracked heads and needed a new blower, and while the tranny is off you might as well replace the main bearings/seals, and since you can swap injectors to the new version and get 50hp, might as well change the other engine' injectors so it runs straight, and while your'e at it, should install airseps, and while the engine is apart, might as well bead-blast and awgrip the whole thing, then the other won't match, so you might as well do that one.........be happy you have to agonize over cutting up the floor to replace a fuel cell or whack off the transom with a sawsall....it gets worse.
Old 11-24-2003, 02:55 PM
Hey other Tom
Good one [img]images/icons/grin.gif[/img] You need see my "tools of trade" post Nov 21 & watch the clip! [img]images/icons/tongue.gif[/img]
