Cavitation plate
I've only My SeaCraft out twice since the rebuild.I was only able to get Her up to 34 + -.
(GPS) She even feels sluggish . I was getting a good 43 + - before.I figured with a foam transom (- 800#'s of WET/rotted Wood),It would at least increase.I did add eXtra glass aroung the top gunnel (new bite for top deck screws) & around every corner inside. Wasn't that much weight. Now here's the ?. My cavitation plate seems to be 1" above the keel . I thought before the re-do that it was even ? Merc. '95-150-25" shaft.20' MA CC. Where should it be ? What could it be ? Scream'n Reels' [img]images/icons/cool.gif[/img] [ December 06, 2003, 12:33 PM: Message edited by: Capt. Brad ]
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Re: Cavitation plate
Capt Brad,
I've always been told the cavitation plate should be even with the keel. Is the engine running up to proper RPM? Have you changed props? Only used it twice since the restore - bad gas/water in the gas maybe? Is the fuel line clogged? Spark plugs fouled? By the way, have you talked to that Creole voodoo woman yet? The way the weather is rippin' up here, I think you must have. |
I think you're supposed to take the boat off the trailer...
Otto And yes, I still believe in the four boat theory... |
[img]images/icons/shocked.gif[/img]
Also, the cav plate is probably not the issue. In fact, as long as you are not getting cavitation in normal operation or the prop is not breaking away in turns, higher is usually faster.
Best regards, Roger http://members.cox.net/rhstg44/Misc/...go%20small.jpg 1979, 20' Master Angler |
Thanks, New gas,same prop, Same everything(well rub rail). I think the oil Mixture was way off,too much ? My tach did not work [img]images/icons/frown.gif[/img] so next outing I'll be able to get that. It didn't sound like I was pushing the RPM up enough. The linkage ? I'll change the plugs use a lil less oil mix & Hold On ! [img]images/icons/grin.gif[/img] I just thought i remebered the cavitation plate being even now its an inch + higher than before.
Scream' Reels [img]images/icons/cool.gif[/img]
