Old 01-03-2004, 12:59 PM
GetReel GetReel is offline
Default Inboard hydraulic steering setup
Have any of you IB guys replaced or upgraded your Hydraulic steering system recently? If so, please share any specs. or components that you used. West Marine has a "package" system, but not cheap and a 20% re-stocking fee to return if it doesn't do the trick... There are so many different combinations it's makin my head spin.... [img]images/icons/confused.gif[/img]
Old 01-05-2004, 01:01 AM
jw jw is offline
Default Re: Inboard hydraulic steering setup
Jeff,
I would check out Hynautics web site or teleflex Seastar website for the info. I have had Hynautics on my big rig for 33 years, they even sold me replacement parts at cost because my origianal parts were obsolete.
justr my 25cents worth
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
Old 01-06-2004, 01:43 AM
sebaugh sebaugh is offline
I replaced my steering (20' CC) with a Hynautics system. I belive it is undersized and does not perform as well as it should. That being said, the biggest thing I overlooked was the tubing setup. Instead of having a fixed piston and 2 fixed lines to it, the piston moves side to side as the wheel is turned. Each end has a line going into it which means I need extra tubing to allow for play (similar to the control cables). I would make sure whatever setup you go with that is ample sized for the motor and that the piston stays in a fixed position allowing for fixed length tubing.
Old 01-05-2004, 02:08 PM
Thanks for the feedback. I've been on line checking this out. Looks like a Sea Star system so far. I'd love an auto pilot...so double the budget...
Old 01-05-2004, 09:19 PM
Hey Jeff, I put a seastar on mine last spring. Thats the project I made the mistake of measuring once and installing twice [img]images/icons/rolleyes.gif[/img] . Anyways I will have to find a boat-us catalog to tell you which set-up I used if you want to know. The hardest thing getting used to for me was the extra turn of the wheelI believe from 3 turns lock to lock to 4 turns. Its awesome though!!! Ill look at work tomorrow-
Old 01-06-2004, 05:26 PM
Craig, thanks, if you can tell me which SeaStar cylinder you used it would help, I referenced Sea Star #1-HC5312, Model BA125-7ATM with 3/8" Nylon reinforced hose with SeaStar 1 Standard Helm...sound familiar???
