I was just wondering how much it would cost to regelcoat my entire boat by a profesional? It is 20 cc seacraft. Also I have no expeirence with painting or gelcoating before but I have a very good friend in automobile body shop, he has never painted a boat before but has done plenty of cars, with my help do you think I should go that route or not. I am going back and forth between gelcoating and painting and I am not definite on one yet, I just want to get some info before I make my final descion.
Thanks, George
20 SEACRAFT SF / 29 SEA VEE F.S.U. / REEL SWEET FISHING TEAMS |
I think you'll find that yards would rather paint and don't mess around with gel coating whole boats.... labor intensive especially when you get topside with all the "non" flat surfaces .... although the raw materials are less expensive than painting....
I would venture a guess that it would be very cost effective to do it yourself .... But lots of sweat "equity" (i.e. sanding) will ensue to get a nice finish... On the “flats” ,hull sides, I could see doing it .... but not when you get into corners and such as with the topside of the boat....can you say sore fingers!!! |
Ha George
Here in Fort Lauderdale it would cost LOTS OF $$$$$$$$ to have someone else re gelcoat your boat. Like stated above very labor intensive. This is not difficult work to do from the technical side it’s just very labor intensive work that you could do your self if you did it approx $500. As far as the painting point of view any good auto painter could paint your boat with the proper equipment and proper breathing equipment. You could prep the job for him to shoot it. The paint alone would probably cost approx $800 to 1,000 for awlgrip primer and paint. I painted my boat myself roller and tip method came out pretty good but spraying will come out a little better. FellowShip |
Thanks FS and Scott,
I talked to a local glass and gelcoat man and he said that I should be scared of having someone gelcoat my boat because it is hard perfect and often leads to cracking. Should I be scarried?
Talk to Ebeach (Jim). He gelcoated his. See if he would do it again or paint? I painted mine. If I had to do it over againg I'd use a bigger garage. I was pretty cramped. My painting costs including sand paper, tape, acetone, paint, primer , Masking-paper and plastic, fillers, tack cloths, and likely 100 other things is approaching $1300. [img]images/icons/shocked.gif[/img]
Came out sweet, Mirror finish [img]images/icons/grin.gif[/img] |
OH IF YOU DO IT YOURSELF DON'T FORGET THE BEER FACTOR THAT'S THE DIFFICULTY OF THE JOB X DAYS OF WORK X 3 = "THE BEER FACTOR"
EXAMPLES DIFFICULTY FACTOR PAINTING BOAT 1.5 DAYS FO WORK 5 1.5 X 5 = 7.5 X 3 = 22.5 BEERS RE GEL COATING 3 X 10 = 30 X 3 = 90 BEERS FELLOW-SHIP [img]images/icons/grin.gif[/img] |
