Old 11-19-2002, 10:01 PM
Jon G Jon G is offline
Default Rich and Steve tank question
When you guys had your gas tanks made do they need the old tank or do you give them the measurements? I'll be pulling mine in a couple of weeks and don't know what I'll find, boats a 74' and was told tank was origional, hoses look ancient at the fill/vent were I can see them. Topped it off for the winter and four days later bilge reeked of gas, no liquid though. I pulled a couple of gallons out and it went away probably a hose or sender but if the tank is origional I want to replace it, its trying to tell me something, better now then next spring.
I support the I'm glad I can afford one boat theory!
Old 11-20-2002, 11:50 AM
Rich Rich is offline
Default Re: Rich and Steve tank question
I had my tank built in RI by the guys at www.lutherswelding.com. I picked them because they were competitively priced with the shops down in Florida, plus I could pick it up and save on shipping. I took out the old tank (75 gal) and used it as a template as far as placing the fill, pickup, vent, and sender. Using AutoCAD I drafted the existing tank exactly as it was, then I stretched it out, made it as big as I could for the space below the console. This, of course, was all before I really started chopping up the boat. I am kicking my self now because I could have gotten a much larger tank in the space than the one I had fabricated (100 gal). Oh well...
The dimensions for the new tank were such that if it got screwed up at all it wasn't going to fit. I made it a point to draft everything out exactly as it should be with strict specs. I sent my drawings to Luther’s and they built exactly what I wanted.
If you are trying to get a bigger tank in there, make sure you have the right dimensions, including the little stuff like height of fill and so on. It would suck to spend $700-$800 on a new tank and find your floor panel rocking on top of the fill pipe.
If you’re interested….
I put my tank drawing (DWF File) up at http://seacraft.snetsol.com/tank/tank.dwf
To view it in your browser you will have to download the Whip viewer from AutoDesk.
ftp://adeskftp.autodesk.com/WebPub/W...lish/whip4.exe
It is a 4 MB download. Once it is finished install it then go back to the link. Right click in your browser to utilize pan and zoom functions.
BTW.. What ever happened to Steve?????
[ November 20, 2002, 12:20 PM: Message edited by: Rich ]
Cape Marine Supply
Old 11-20-2002, 02:00 PM
John R John R is offline
I talked to Steve about the "Where is he" a little while ago, he's still in fish mode and not in boat mode yet - says he'll come back once the fishing is done...
He's over on my site as "Capesams" if you REALLY want to harass him [img]images/icons/grin.gif[/img] [img]images/icons/tongue.gif[/img]
He's a helluva nice guy
Surf and Boat fishing for
Striped Bass
Old 11-20-2002, 03:19 PM
Thanks Rich, I just want them to make the tank the same size as original,50gal I believe, and I'm pretty sure that I will have Luthers do it its not that far. I'll check out your CAD drawings thanks for the info. I'll post again when I pull it out.
