Old 02-03-2003, 09:12 PM
EBEACH EBEACH is offline
Default 25” Transom and glass thickness
Does anyone know the thickness of the outside glass on the 20’ sceptre or SF transom (1970’s)? Assuming I taper the glass back about 12 to 1 on the repair, do you think the structural integrity will be as good as new if I do the repair from the outside? [img]images/icons/confused.gif[/img]
When raising the transom 5”, does this have any impact on a cable steering setup?
Old 02-09-2003, 11:33 AM
Default Re: 25” Transom and glass thickness
Anyone with a solution for the steering problem? Hydraulics would work, but its rather expensive.
Thanks
Old 02-09-2003, 12:18 PM
John R John R is offline
Eb if you need to get a new steering system - those No Feed Backs are fairly cheap right? Not sure on the HP ratings probably below 150 but these systems are about $200. The Hydraulic is about $800-1000 I think...
Surf and Boat fishing for
Striped Bass
Old 02-10-2003, 01:08 AM
The problem is if I raise the transom 5 inches, the splash well will be too low to run a steering cable. [img]images/icons/confused.gif[/img] I would think Hammer and Tim D would have run into this?
Old 02-09-2003, 04:07 PM
jw jw is offline
Ebeach,
I have my 20sf cc I/o in my shop with the engine and outdrive I can measure the glass tomorrow. My transom is about 3.5 inches thick.
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
Old 02-11-2003, 09:07 AM
timd timd is offline
E-
I'll take a picture today and post it.
Tim Dugan
