Old 04-01-2003, 10:51 AM
tangofniro tangofniro is offline
Default inside or outside
Hey guys,
I know that there has been a lot of discussion in the past on transom repair but since a lot of repairs have went on in the last 6 months maybe some new facts will arise.
On a transom replacement can anyone give me the pro and cons of both going from the inside and going from the outside. I would like to go from the inside but the stringers look to make that idea very hard. Going from the outside though looks to cause quite a bit of finish work. I am looking for the best way to go even if it is a little more work.
Thanks I know that this has probably been discussed a million times but here we go for a million and one
Old 04-01-2003, 12:11 PM
Default Re: inside or outside
I REDID MY 23 FROM THE INSIDE AND I KNOW THIS IS A PERSONAL THING BUT FOR ME GOING FROM THE INSIDE MAKES MORE SENSE FOR A FEW REASONS ALL OF THEM ARE A STRENGTH THING. ONE IS I ADDED A KEEL FOR EXTRA SUPPORT FROM THE CENTER WOOD STRINGER TO THE TRANSOM ANOTHER REASON IS THE AMOUNT OF GLASS ON THE INSIDE WALL OF THE TRANSOM IS NOT AS THICK AS I LIKED IT SO I MADE MINE A LITTLE OVER ¼ “ THICK. YOU CAN ALSO SUPPORT THE TRANSOM FROM ALL AROUND THE HULL BY BUILDING IT UP FROM THE INSIDE WITH EXTRA LAYERS OF GLASS I ADDED 8 EXTRA LAYERS AND YOU CAN ADD EXTRA GLASS TO THE INSIDE SIDE OF THE OUTSIDE WALL OF THE TRANSOM WITH OUT ANY PROBLEMS (I ADDED TWO EXTRA LAYERS). AS FOR THE STRINGERS THAT’S NO PROBLEM AT ALL JUST CUT IT FREE AND GLASS IT BACK ADDING ADDITIONAL GLASS FOR MORE SUPPORT. I DID MY TRANSOM ABOUT 1 ½ YEARS AGO NOW AND AT THAT TIME THE COMPOSITE MATERIAL FOR TRANSOMS HAD ONLY STARTED MAKING INROADS INTO THE MARKET AND THERE WERE SOME BUILDERS THAT WERE HAVING SOME PROBLEMS SO I WENT WITH PLYWOOD. I HAVEN’T HEARD OF ANY PROBLEMS IN A WILL AND NOW A DAYS I MIGHT HAVE GONE WITH THE NEW COMPOSITE MATERIALS INSTEAD OF THE PLYWOOD.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
Old 04-01-2003, 12:25 PM
Fellow Ship what tools did you use for the job of getting around in those tight spaces? UI plan on using a router and I guess side grinder and chisels. Any other that may be some help to me? I am in the process of ripping the old foam out to have acces to the bottom of the transom and around the stringers. I guess you would know it is tedious work.
Thanks
Old 04-01-2003, 04:53 PM
cSickNick cSickNick is offline
I struggled with the same questions, but decided on a 3rd option. Going through the top. It's out there somewhere.
I found that the old transom came out easily with the old chain saw. Also electrical paddle bits with extensions do a great job on mulching up the hard to reach areas.
I have some picts if needed.
For the pro's and con's, i will leave it to the experts. It appeared to me that it is a "toss-up" and that ones most weighted varibles(Cost, experience, time, restoration, materials, etc ..) would decide which option is best.
For me, lack of experience, cost and time were the heavy weights. This pointed me to an external person to do the glass work that allowed me to remove the old transom to save $ and time.
- Nick
Old 04-01-2003, 05:25 PM
THE SIDE TYPE GRINDER WAS MY FAVORITE TOOK ON THE FIBERGLASS CUTS THROUGH THAT STUFF LIKE BUTTER MAKE SURE YOU USE A MASK AND SOMETHING FOR YOUR EYES THAT STUFF GETS SPREAD ALL OVER. AS FAR AS THE WOOD SOME GUYS WILL TAKE A SKILL SAW AND SET IT FOR 1 1/8 “ AND CUT A CHECKERBOARD PATTERN IN THE NOT SO ROTTEN WOOD THEN CHISEL OUT THE CHUNKS. I USED EVERY THING EXCEPT MY WIFE’S KITCHEN KNIVES. I ALSO USED A SANDING WHEEL ON THE GRINDER TO CLEAN UP SOME OF THE RUFF PLACES THEN ADDED 2 LAYERS OF GLASS TO STIFFEN IT UP A LITTLE. I USED THE WEST EPOXY SYSTEM NOT CHEEP BUT WORKS GREAT. YOU CAN SEE MY WORK ON THIS SIGHT UNDER KEN MCGOVERN 23’ BOATS.
WHAT ARE YOU GOING TO USE PLYWOOD OR SOME OF THE NEW COMPOSITE MATERIALS?
Old 04-01-2003, 05:35 PM
I plan on using some 1/4 luan. Should finish up the foam removal today. I plan on using epoxy just not west.
'You laid 2 layers of glass before you even started installing the new core? How long did you wait before installing the core on the old skin?
Anymore have good ideas on templates to use on the transom besides cardboard?
