Old 06-19-2003, 01:09 AM
John R John R is offline
Default Gas Fill / Tank Vent Ground
Did any of you connect a ground wire to the hulls bonding ground to the Tank Fill and/or Tank Vent? there is a wire (green - for hull ground, right?) next to my tank vent but there is nothing to actually bolt it on to. The tank vent looks judt like and is arrange like this Perko (which it might be): http://www.perko.com/cgi-bin/perko.p...509-vents_info ...
Thanks,
John
Surf and Boat fishing for
Striped Bass
Old 06-18-2003, 03:09 PM
Default Re: Gas Fill / Tank Vent Ground
John , you don't need to ground the tank vent but the fill needs to be grounded to the tank first then the rest of the boats grounding system.
Old 06-18-2003, 04:27 PM
ScottM ScottM is offline
Dieter Sprockets
My boat doesn't have a bonding system - is that bad? Just so I'm sure we're talking about the same thing, it would be a metal bar fixed to the keel with a ground wire to it, right?
Old 06-18-2003, 05:27 PM
I HAVE A SEPARATE LITTLE TAB ON THE GAS TANK THAT I ATTACHED MY GREEN GROUND WIRE TO I ALSO ATTACHED A GREEN WIRE TO THE GAS FILL I THEN CONNECTED TO A SEPARATE WIRE BLOCK UNDER MY CENTER CONSOL AND THEN RAN A THICK GREEN WIRE FROM THAT TO MY BRASS THROUGH HULL SCOOP THAT FILLS MY LIVE WELL. IF YOU DO IT CORRECTLY YOU NEED A BOAT GROUND PLATE THAT COST’S ABOUT $50.00 AND HAVE EVERYTHING CONNECTED TO IT, BUT MOST GUYS ARE OK WITH THE SCOOP SINCE IT IS ALWAYS IN CONTACT WITH THE WATER OTHER GUYS USE THE MOTOR SINCE IT IS IN THE WATER AS WELL I LIKE THE BRASS OF THE SCOOP NOT THE ALUMINUM OF THE MOTOR ALL MY ELECTRONICS GREEN GROWN WIRES ARE CONNECTED TO THAT WIRE BLOCK AS WELL.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
Old 06-19-2003, 12:30 AM
ocuyler ocuyler is offline
Can I use the drain plug fitting?
Otto
Old 06-19-2003, 08:10 AM
PipeDreamsMarine PipeDreamsMarine is offline
I would use a DYNA plate for all of the bonding system. Bonding to though hulls is asking for trouble, if you keep you boat in all the time. And bonding to the motor..well just think about it .. Aluminum and salt water and a twist of electrons....
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
