Old 07-01-2003, 04:23 PM
esoxesox esoxesox is offline
Default Need help with "bruised" hull
Hello Boys,
I've found a little spot, about the size of a matchbook, that has been cut out and replaced with a glass patch by a previous owner. I believe it is a cheapo repair job from a hole caused during trailering. I never noticed it until it I was following someone and they commented on the black spot on the hull. The soft spot is right on the keel, center-line if you will, and adjacent to the thru-hull fitting on the forward fish box. If I leave the boat in the water it take on less than a gallon of water overnight but the boat is on a trailer 99% of the time. I drilled a few pilots and got oily dirt from the hold.
So, what to do? This is a freshwater boat and I am planning on some major teardown projects this winter. At that time I could "do it right". I REALLY want to get on the water ASAP and would like to postpone the "right" way until later. Can I get by drying the outside surface and applying marine-tex or West or something like that?
Any help would be great.
Thanks
Scot
Temerity => 1973 20' CC
Jitters => 13' Whaler
At Large on Lake Superior
Old 07-01-2003, 07:36 PM
John R John R is offline
Default Re: Need help with "bruised" hull
Look up the threads from Marc - there was a good one on this subject - but here is the hull repair pics he had - this might help.... http://www.theboatzone.com/gallery/markhull
Surf and Boat fishing for
Striped Bass
Old 07-01-2003, 07:41 PM
Thanks for that John.
Update - I pulled out the "matchbook" and found wet wood...damn...
Old 07-01-2003, 10:36 PM
EBEACH EBEACH is offline
Don't worry too much. I think that wood is just a backing between the liner and the hull. It's there to give more meat to the thru hull for the fish box. I'd leave the wood there, and just let it dry out a bit. Pull out your drain tube going into the fish box. That is most likley where the water is coming in. pull the tube and let the wood dry out. Then use 1/2" PVC to make a mold for the drain. No more water leaking past any tube. It's an easy fix. The 1/2" pvc will give you an 7/8" hole. no need for the coupler.
how to fix the drain tube
Old 07-01-2003, 10:56 PM
saltydog saltydog is offline
Ebeach is right about that drain, it is probably were some of your water is coming from. Ran into the same problem on Otto's 23. As for the, "matchbox" if you are going to do some major renovating and wnat to get her in the water right away you can let the hole dry out for a while, use halogen lamp on it, not too close though! Grind a bevel back around the perimeter of the hole at about 12 to 1 ratio get some west system and start laminating. Use mat first then two layers of cloth then mat then two layers of cloth until you come out past the bevel. Not going to look good but will give a good hold and keep water out until you are ready.
Old 07-02-2003, 02:37 AM
Thank you boys, you have lifted a dark cloud that had descended over my little 20 footer. I had visions of a full scale tear-down this winter to fix that thing up. With clear skies and warm air (70's that is), I ought to be able to get rolling by the weekend. Might only be a 6 pack job, though I almost passed that count tonight just thinking about all the work I might be in for. [img]images/icons/rolleyes.gif[/img]
I've reviewed the archives and the specs and everything else I could find. I was under the impression that the only wood in the boat, aside from the wood core in the decking, was in the transom. Are there other places that I'm going to find rotted, wet wood?
Thanks again,
Scot
[ July 02, 2003, 01:38 AM: Message edited by: esoxesox ]
