Old 07-05-2003, 11:23 AM
toddkp toddkp is offline
Default outboard tune up
i recently aquired a 115hp evinrude that has low hours and was professionally maintained except for last winter, i suspect that it wasn't winterized. any help as to how i could personally clean it up? it looks clean almost spotless but the not being winterized thing scares me a little. thanks for the help.
Old 07-06-2003, 01:06 AM
BARNABY55 BARNABY55 is offline
Default Re: outboard tune up
I too had a 115 that sat for probably longer than yours. If you have fears, I would take it to someone you trust ( if there is such an animal) and spend the fee for a complete check. I did and it was the best $65.00 I spent. At least now I know what I have. Just so you know, I needed carbs rebuilt due to sitting and a stator.
Ted
Old 07-06-2003, 01:09 AM
John R John R is offline
Todd - there is nothing to really winterize, it's a 2 stroke and doesn't / shouldn't hold any fluids to freze and crack - even with last years weather... Should still go and lube up everything and then some but unlike a closed cooling 4 stroke, there are no cooling sections to anti-freeze. Might need the carbs cleaned or tuned...
Surf and Boat fishing for
Striped Bass
Old 07-05-2003, 04:15 PM
TUGBOAT TUGBOAT is offline
And don't forget the Water Pump !
Scream'n Reels'
I had to move My Ice Chest forward last Winter to Keep My engine from getting to cold !! [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 07-05-2003, 09:09 PM
thanks for the help, i appreciate it. figured i'd ask around before messing with it.
john r- don't forget about the BI tourney, and tell a few if you think of it, should be quite fun if the size of bass right now is of any indication...
Old 07-05-2003, 11:31 PM
SECF3114M73J SECF3114M73J is offline
Pull the spark plugs and squirt some oil,WD 40, or the like into each cylinder. Crank the motor a few times with the plugs out.Put new plugs in. Hook it up to a hose using muffs. Give it some fresh gas and oil and light it off. If everything works O.K. change the lower unit grease,do the general lube,and you're good to go.
