I just took possession of a '85 23 SC CC, that went under for 12 hours. I'm trying to organize my game plan for going through the entire boat.
There is also a soft floor section approx. 2x4' next to the console that I intend to repair. This will involve removing the TTop and console to do it right! While it's apart The fuek tank will be inspected / replaced if necessary and all wiring and systems replaced, as well. Based upon everyone's experience what else should I consider doing, looking into? I plan on keeping this boat for a long time and have a bracket and full transom project in mind as well, but that may be down the road a year or so. Any suggestions would be appreciated! Thanks Rich |
HA DINK
Looks like you could have a nice boat there, not that old yet, so you might not have too much to do on it. It’s hard to say what you will need to do, but a good inspection is defiantly in order. I might be concerned about all the electrical parts and wiring on this one since it sank. If salt water gets into things you could have some real frustrating times figuring out what’s happening like gages, switches, keys, wiring harnesses, pumps and what ever. I would first try spraying everything off with fresh water get dry and then spray with a corrosion x spray. I don’t know if you have a engine on her but if you do that might need quick professional help asap. Good luck FellowShip |
Fellow-ship
I'm going into this expecting to replace all electrical parts. I'm not so sure about the tank; as a minimum I will pull the covers, drain the fuel into a water separator filter and go from there. I'm assuming the hydraulic steering system is Ok as it is holding the oil. While all the hatches are off can you think of anything else I should be checking? Rich |
Thedink-
Definitely replace all wiring, check flotation foam (if soaking wet....dig out and replace). Regarding your tank....it might be fine once you flush it out....but I would personally replace it now while you're doing all of this work. Just imagine what a pain in the arse it will be to have to remove the console and all that pretty wiring....2-3 years down the road when the tank starts leaking. -Ed- |
Welcome Dink
Honestly …. I personally would strip the hull and start fresh ….. There are too many things that can show up later in a boat that has sunk as Ed alluded to …..And your tank is approaching 20 years anyway and you say your keeping her …. If you do keep the tank I would have it cleaned (inside) and that’s not an inexpensive proposition. [img]/images/graemlins/shocked.gif[/img] Water in the stringers would be a major concern (cracked fiberglass or separation from the hull as a result of freeze/ thaw cycles …a northeast issue) Wiring replaced without a doubt If there was an engine to be salvaged…. That should have been addressed immediately …..leaving it without attention after the boat was raised …Salt, air and an engine ….not good Start from the bilge up ….that way you know exactly what you have As it is most of us here are doing complete restorations anyway ….. Regardless if it went under or not [img]/images/graemlins/cool.gif[/img] Oh yeah ...something like the hydraulic steering , if working , should be fine… just get the salt off |
Agree with what Scott said.
Strick
Scott, Ed & Company
Thanks for your feedback. Once it starts getting over 30 I'll begin to open her up and start looking at what I really have. I didn't consider the stringers or the foam soaking up water and don't know how to check this properly. Suggestions anyone? Scott: Re: the engines, they were serviced immediately after they went down but I'll have someone go through them in a week or two . If they can be saved, that would be home run as I went into this project thinking they were scrap. |
Scott
A update of my progress. The fuel tank, live well and rear filler hatches were all soaked and have been stripped and await new core material and reglassing. The decks are also soaked and I'm now removing the core material, as well. The fuel tank and tank support has been removed as it was soaked and drooping, as well. The tank looks in real good condition though and I will have it checked. I've noticed from other related posts that some members have applied resin and a coal tar coating. Does anyone know where to purchase this tar coating in the Northeast? I have tried to post pictures but are still having trouble. Any suggestions? |
I would consider a total rewire in the works.
Hi Dink
My sceptre sank in feb 2003 snowstorm. Loose all the fuel,electronics and gear wont last more than a year anyway. Salt water will wreck the fuel tank in about 8 to 10 months,i had to replace the tank due to a leak. Check the fuel tank hatch cover core for delam all my other hatches are teak so they were ok. Stringers and foam dried out with help from wet/dry vac and heater.Good luck with her.
shellfish |
