I measure about 13 degrees on my mine......does anyone know what the specs are as to the transom angle on a 1970's 23cc. Thanks
Strick
I came up with about 12 degrees on my 23 Sceptre.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
Thanks Steve
Anyone else have anything different? Strick
12 degrees here also
OK thanks guys... I've re-measured and re-measured and still get 13 degrees. I'm using a protractor and table saw mitor for my measuring devices. Maybe my boat is different.
Strick
Here's how I'd measure it:
1. Hold your framing square so the short leg points up and the long leg points toward the bow of the boat. 2. Place the square so the tip of the short leg contacts the transom and the long legs sits flush against the bottom of the keel. 3. Divide the measurement from the inside corner of the square to the transom on the short leg by the measurement from the inside corner of the square to the transom on the long leg. 4. Take the inverse tangent of that number (calc.exe in scientific mode) can do this and you have your transom angle. Does that make sense? If not, just send me the measurements. [img]/images/graemlins/smile.gif[/img]
Brian 1981 Mako 17 |
