I have a 1986 center console with a T-top and noticed last time out the console moves in it's footprint on the floor and the fastening screws backed themselves out of the floor.Upon further investigation almost all the mounting holes in the deck have been egged out from the screws moving over time.I've got a few ideas on how to fix this but would like to hear some input to see if anyone has any creative fixes to this--thanks [img]/images/graemlins/shocked.gif[/img]
Ha Bottomline
The center consol was screwed with sheet metal screws into the deck through little 3” x 3” plywood blocks approx ½ thick (lamination). Over time the wood rots and with the added pressure of the t-top swinging back and forth the rotted wood can no longer support the C.C. and the T-Top. My approach is always “When In Doubt Cut It Out”. I would remove the C.C. and T-Top then remove the top layer of glass replace the deck lamination (I would only use Plywood in that area) and then replace the top layer of deck glass. FellowShip [img]/images/graemlins/frown.gif[/img] |
Thanks for the input,unfortunately with the season so short here in Ma. I don't have the time to get into that right now-coupled with the fact I have a brand new outboard that needs some running.I came up with the idea of drilling out the old holes and refilling them and taking a piece of aluminum and using it as a backing plate under the floor on the corners.I have also been told to use 5200 adhesive to run a bead around the perimeter of the console?
Take t-top off for this season. Fix the console and add the t-top back this winter. A t-top coming loose could really cause some major bodily injury.
Before I had my T-Top installed, I remounted my console.
Prior to pulling it up I drilled out the mouting holes to accept. no. 12 stainless machine screws. The screws that came out were no. 10s and some of the holes were stripped. I pulled up the console and cleaned all of the old silicon sealer from the console base and deck. When I set the console back down, I bed it in a thick bead of 4200. I put a nice finishing washer on each new screw and sealed them with 2400 as well. Then I ran a bead of 4200 around the base and smoothed it out for a nice finished look. That thing ain't never movin'...unless I really, really, really want it to!!!! [img]/images/graemlins/smile.gif[/img]
Brian 1981 Mako 17 |
5200 is a tremdous commitment, i would go with something a little less aggressive.
1986 Seacraft 23CC etec 250 Portland, Maine |
Brian,what is the difference between 5200 and 4200 and how permenant is it?
I would have drilled out the old holes but the screws I pulled out I believe are 1/4" Do they make stainless screws bigger than that? I guess I'll have to fill in the old holes.Any special way to do this?
Scott nailed it on the 5200 vs. 4200 thing. [img]/images/graemlins/smile.gif[/img]
You said above that you have room to access the underside of your deck, right? So, drill the holes out and fill them with thickened epoxy. Then redrill and thru bolt the console and use large fender washers on the underside of the deck and lock nuts w/ the nylon inserts (seal each screw/bolt w/ 4200). Then run a bead of 4200 around the base to seal it off.
