Old 06-30-2004, 02:52 PM
optiguy optiguy is offline
Default New Project
Well today I started a transom job for one of my customers.
I will be postings pics as I go along. The boat is a 1978 23'. The one thing that is amazing is tihs boat is dry. The transom has been wet but the stringers are dry as a bone. At one time somebody did some work back here and did a misrable job. As you can see, the aft access has been glassed over and with only a layer of mat. Well here is the first set of pics. More will follow when I remove the outer skin and live well over the next few days.
Bill
Old 06-30-2004, 03:45 PM
pogden pogden is offline
Default Re: New Project
So you will be doing it from the outside in?
Worry less, Fish more!
Old 06-30-2004, 03:59 PM
Yes, this will be an outside repair as the ply is very wet across the entire transom and the outer skin has come away from the ply across the entir transom. The customer does not want the live well and by removing it allows easy acess to the inside for adding large knees for more motor support.
Old 07-01-2004, 03:45 PM
Todays progress in pictures. The live well and outer skin have been removed. If you notice on the Port side is an old repair as the plywood is different and better than whats around it. The Stb. side is dry rotted on the whole side.
The rest or the trans is soaking wet. Tomorrow the wood removal starts and final cuts up near the towing eyes. I dread getting them out as Seacraft installed them before the deck was put on and access is almost nill. In the picture showing a tool, who can guess what it is and what blade is on it. For those who don't know what it is, if you ever get a chance to use one you will never cut fiberglass with anything else. No dust, no itching no problem.
Bill
Old 07-01-2004, 09:37 PM
It's an occilating saw. I have the same one but a battery powered version. I use it for cutting casts on horses out in the field. Never thought of using it on the boat however. Thanks for the tip
Strick
Old 07-01-2004, 11:44 PM
warthog5 warthog5 is offline
Got a link to the tool? I alway's need a new tool. [img]/images/graemlins/smile.gif[/img]
