Old 08-04-2004, 09:43 PM
jedgar jedgar is offline
Default Trailer for 23 Scepter
Guys,
I'm looking for a new trailer for my 1985 23' Scepter. The boat is CSY built with a 144 gallon fuel tank and twin 115 Suzuki 4 strokes.
Does any one have a true weight for a similar boat ?
The trailers I'm looking at are Loadmaster or Rolls tandem axle drive-on aluminum. Both are available in either 6,000 lb or 7,000 lb capacity, the difference being the rating of the axle sets. Both Loadmaster and Rolls tell me that the 6,000 lb models are adequate for my boat, but for some reason I have a feeling that the boat with full fuel, etc. may be pushing that weight and I would rather have a trailer that is underloaded rather than one loaded right to it's limit.
So, if anyone out there has actually weighed a similar model, please let me know.
Thanks.
Old 08-05-2004, 09:30 AM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Trailer for 23 Scepter
My father's '82 23 Sceptre OB is 3,300# dry, so I'd guess your '85 is the same weight. Add your 2 engines @ 415# each, full fuel ~864# (6#/gallon), and you're up to 5,000#. The 6000# should suffice, unless you carry a lot of gear with you.
BTW, you're boat was built by SeaCraft Industries. Having an '82, I always thought my father's was a CSY also, but I found out by a very reliable source [img]/images/graemlins/wink.gif[/img] that CSY only produced the 23 for a short time in 1980/1981, at which time SeaCraft Industries took over.
Old 08-07-2004, 09:10 AM
So Scott,
Are you saying the 3,300 lb dry weight was obtained by actually weighing the boat ? If so, with the engines, fuel, and gear I would want to carry for week long trip to the keys, I would definitely want to upgrade to the 7K capacity trailer.
Not too sure about the CSY vs SeaCraft Ind as builder of the boat. Who was your "reliable" source ? I do know one thing, as far as build quality from a structural perspective, I have no complaints - the boat is plenty strong with heavy glass work. A few rough edges here and there, finish work inside the boxes etc. not super, but as good or comparable to any other major manufacturer of that era.
Thanks for everyones input.
Old 08-08-2004, 09:56 AM
Dieter Sprockets
So Scott,
No, this comes from a SeaCraft spec sheet for the '79 model year. I'm willing to bet there is no substantial weight difference between '79, '82 and '85.
See Capt Chuck's post here about my "reliable source".
Old 08-09-2004, 03:29 PM
ALWAYS go with a higher capacity trailer if there is any question. On my way to the Keys last year, (just over 500 miles) I actually weighed my 1972 Seafari 20' with full fuel and fishing gear onboard. (It cost $5) Including my Magic Trail 5500 lb. capacity trailer (which weighs 872 lbs according to the mfg), my total towed vehicle weight was 4,612 lbs. My motor weighs 406 lbs, and I had 79 gallons of fuel on board. (43 in the main tank, and 2 18 gallon portables)
That works out to 2,860 lbs for hull and fishing/boating equipment. With my 4.0 liter '95 Grand Cherokee, I only tow at 65 mph. (I can tow at 75 mph, but fuel economy falls from 13 mpg, to less than 10 mpg.)
And my trailer did NOT come with brakes. [img]/images/graemlins/shocked.gif[/img]
I have aftermarket galvanized discs to install this fall. [img]/images/graemlins/smile.gif[/img]
Fr. Frank says:
Currently without a SeaCraft
Old 08-13-2004, 07:48 PM
So, I guess no one out there has actually weighed their 23' twin outboard.
What capacity trailers are you guys with 23s hauling your boats on ?
Old 08-05-2004, 11:10 AM
ocuyler ocuyler is offline
jedgar,
I agree with ScottM's assesment with the exception that the trailer itself weighs in at around 1000 pounds. If you add some gear to that, your'e over 6000. I agree with you that I'd rather have the heavier trailer.
Be sure to get disk brakes, LED lights (a must, even if you unplug) and torsion axles. That combination can be hauled anywhere at 70 MPH with a standard 1500/150 truck in complete safety.
Otto
Old 08-06-2004, 06:42 AM
How would you know Otto...... yours sits at home all the time...and you don't even own a Scepter...well maybe you do. .but anyway.. I'm sure it sits outback like the 23cc does..... [img]/images/graemlins/cool.gif[/img]
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 08-06-2004, 12:47 PM
I was trailering boats and heavy machinery when you were in diapers, boy. Show some respect...
Otto
Old 08-06-2004, 01:46 PM
Dieter Sprockets
This affects the tow vehicle you can use, not what the trailer can carry. As long as your rig doesn't exceed 5,500#, I would think the 6000# would work fine. Then again, I also agree with going up one more level for the "just in case" factor. [img]/images/graemlins/smile.gif[/img]
