Old 08-19-2004, 10:18 PM
mdurfeeh mdurfeeh is offline
Default 72 Seacraft center console floor repair?
I have a question to all Seacraft nation and that is I inheirited my dads seacraft it has seen little ocean water over the years and what I mean is maybe on an average
of 8 saturdays a summer fishing and the last 5 years stored it was only moored for 2 years since 1972 other than that always trailered.The floor has spider cracks and are lifting up in areas.The transom seems solid there is no cracks or flex and the hull has never been damaged or cracked.I know you guys talk alot about stringers there again somebody who knows would have to check. I would like to get the floor repaired this fall and maybe you guys could recommend somebody who has done one?I live in the southeastern Mass area.I am new to the site and look forward to hearing your comments.
Old 08-19-2004, 11:20 PM
Ryan Ryan is offline
Default Re: 72 Seacraft center console floor repair?
welcome, the first thing to do if you are thinking about restoring, but you dont really know a whole lot(like me) would be to have a surveyor or someone check it out. If you just want to use the boat as is you should probably check the fuel system lines tank etc. look for rot around the transom,there is a way to see if your transom is still strong by putting pressure on the lower unit up and down while you look for flex on the back of the transom. the other guys who actually know what to tell you will be around soon. Tell us more about your SC, and we always love to see pictures.
Old 08-20-2004, 08:54 AM
Thanks Ryan,This boat has the gas tank under the front seat
of the console and it has been replaced a couple of years ago.I believe it holds 42 gallons.There are no cracks on top
or around the transom.The console is original, windshield and all.The screws at the bottom are falling out but over all its in good shape.This boat has a 115 johnson on it.The boat was not beat on.This model has the high bow rail and the bench seat.I am capable of removing the console and preparing the boat for a glass man to do the work.I was hoping to find somebody who moonlights to do the work.This floor has got a little flex in it and the spider cracks are lifting up in a couple of spots.Also I might add probably 10 years ago my dad had the floor in front of the console replaced and that now has flex to it.This had to be done because water got through the cover and froze in the winter.
Old 08-20-2004, 10:28 AM
ScottM ScottM is offline
Dieter Sprockets
This one has "Ed Mancini" written all over it. Contact Ed via this site, either by PM or email. He did some transom work for one member already.
Old 08-20-2004, 06:34 PM
Thanks Scott, great tip I live in Bridgewater and I would rather have somebody like him that knows Seacraft and is local.Can someone give me Ed"s email address.I have pictures
ready to send.
Old 08-20-2004, 07:00 PM
Rich Rich is offline
Durf,
I live close to the cape, and I swing down thru bridgewater on a daily basis coming home from work. I have completely gutted and am slowly rebuilding my 1972 23'.
Let me know, If you want I could swing by some evening next week.
Rich
Cape Marine Supply
Old 08-20-2004, 07:12 PM
Dieter Sprockets
edward_mancini@hotmail.com
He'll probably explain everything to you, but he cut his teeth doing glass work up in Newburyport at a buddy's shop, then did some work on cSickNick's 20' Seafari on this site. He's a Mako owner so watch out for him. [img]/images/graemlins/wink.gif[/img] [img]/images/graemlins/grin.gif[/img]
