Old 11-14-2004, 01:30 PM
albacore00 albacore00 is offline
Default water inside hull
a question for anybody in the know. I have a 1974 full transom 23 footer.I've noticed that after a good rain water collects between the outer hull and the first step in the full inside the boat, under the deck. Is there a leak in the scuppers at the corner of the transom and the deck?
Does anyone understand what I'm talking about?
Old 11-14-2004, 10:58 PM
Ryan Ryan is offline
Default Re: water inside hull
Peter, are you saying that water collects against the outside stringer? If thats the problem than you must have had the drain tube glassed over in a repair or that drain may be clogged. Each stringer should have a drain a couple inches forward of the transom to get that water down to your bilge pump [img]/images/graemlins/confused.gif[/img]
Old 11-15-2004, 08:40 AM
abl1111 abl1111 is offline
Taste the water. I bet it's fresh water, either from rain or a washdown. Mine gets water there from the (4) side vents located on either side of the hull. The water 'should' drain into the bilge, via a hose through the stringer, for that exact purpose.
However, those hoses can and will get clogged very easily, especially with the older hull - not letting the water drain into the bilge and therefore collect.
On my boat, I keep (2) large sponges in that area anyway ( I have an i/o, and this small amount of fresh water goes thru the drain hose well, but gets 'pooled' near the motor beds - just a little - I did not want to cut a hole through the motor bed just to drain a little water ! )
The sponges are almost always bone dry, but sometimes there is some water there. No biggie.
Old 11-15-2004, 10:35 AM
Scott Scott is offline
Old 11-15-2004, 05:13 PM
ocuyler ocuyler is offline
NICE bilge, Scott!
Otto
Old 11-18-2004, 12:28 PM
NICE bilge, Scott!
Otto ...Your Buddy with the "Action Power Grip" [img]/images/graemlins/shocked.gif[/img] seems to like it !! Now where's that "Inspector"
Finny... details details ....here's your Laser pointer [img]/images/graemlins/grin.gif[/img]
Old 11-15-2004, 06:25 PM
Finster Finster is offline
Scott, where's the lazer pointer? [img]/images/graemlins/grin.gif[/img]
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
