Any recommendations (brands, model numbers) for a horizontal grinder type tool that can also be used as a buffer. Sorry, air tools are out, must be electric. Also, anything special to look for regarding discs, pads, etc?
Not sure about dual purpose grinder/buffer.
For buffers: the two that were recommend to me are makita 9227c and Porter-Cable 7424 for buffers. I have the 9227c and I've only used it on my car. It's very nice. Grinder: I have a little Makita 4" grinder that's survived 3 boat projects and many other nasty jobs. Love it!! |
I picked up a Dewalt Buffer in pawn shop last spring. It kicks ass...and its paid for itseld twice with all the beer my friends have given me for borrowing it. hmmmmmm.....beer
1986 Seacraft 23CC etec 250 Portland, Maine |
With my grinder if you used it for a buffer you could buff your boat all the way down to the stringers in less than a minute. [img]/images/graemlins/crazy.gif[/img] [img]/images/graemlins/confused.gif[/img] [img]/images/graemlins/grin.gif[/img]
FellowShip |
I used to use a milwaukee buffer/sander when I ran a boat detailing service. Be sure to get the little 5/8 to 1/2 inch adapter and several wool buffing pads. You can flip the pads over and use both sides which is a great time/money saver.
They sell the buffer at the home depot but you will have to go to a marine store (B.O.W.) for the adapter and the Pads. |
Thanks for all the input. To be more clear in my question, when I used the term grinder, I was thinking of grinding fiberglass, not metal.
The "metal" grinders have an accessory attachment the uses "sandpaper" disks and a flexible backing plate .... Removes fiberglass quite rapidly!! 36 and 50 grit chew through stuff REAL fast and WAY WAY too fast to use as a buffer 10k rpm
![]() sanding disks kits for grinders I have the “buffer” as Big shrimpin mentions the 9227 … and have the sanding disks for that also but the smaller Makita works better for glass removal IMO I also have one of these …a DA sander / polisher. Another good sander although I go through sandpaper quick with this one. I use this more after the rough grinding is done Porter Cable |
dcobbett, I have a Nikota sander/polisher that goes from 1k-3k rpm and takes a 7" disk. It wasn't expensive and seems to be holding up good under the constant use.
