Old 05-20-2005, 11:18 AM
kwluis kwluis is offline
Default New Sea Craft
I know this is a classic Sea Craft site and I don't want to get blasted for posting this, but I just picked up my new 2005 Sea Craft and I wanted to list my initial impressions.
All electical connections had heat shrink terminals.
The pumps had quality hoses and hose clamps.
The hose connections to the pumps were filled with silicone.
The console was laid up super heavy duty. The mounting screws for my C-80 weren't long enough to go through.
The trim tabs were Bennett tabs!
The T-top was mounted to the console & deck with aluminum backing plates.
All hinges on the boat are Gemlux stainless and the wheel is an Edson.
I would like to see the console redesigned some how. The only access is through 2 hatches one on each side at the bottom. I'm a small guy and I am having difficulty getting to the back side of the electronics.
The wiring is kind of bundled up. I am use to seeing the wiring in the new yachts that my dad does where all the wires are run in a line and it's easy to determine what the wires are for.
The access to the fuel filter is through a round plate. Once again, the wires are bundled in fron of the filter and it seems like it might be difficult to change.
The in deck live well is huge, but when I was hosing off the deck last night, a lot of the water from the hose went into the live well...the hatch isn't sealed. So when I scrub down the deck, chances are the live well will fill up with soapy water. Soap in a live well isn't too good.
Last, when the hawse pipe was installed, 2 of the screws went in at an angle and tore up the edge of the inner liner under the gunnel. You can't see it unless you lay down and look up.
All in all, I am very happy on what I have seen initially.
I had 2 people that I respect a lot when it comes to boat building check it out when I got home yesterday and they both were impressed/surprised with the way the boat came out. I plan on taking it out tomorrow and breaking it in.
We'll see how it holds up after a year of hard use down here in Key West.
Luis Leal
www.coolseasfishing.com
2005 Sea Craft 23
Old 05-20-2005, 11:55 AM
Sleeto Sleeto is offline
Default Re: New Sea Craft
Luis,
The design is CLASSIC - that's what matters - Welcome.
Congrats on your new boat!! I wish you much luck and happiness!!
What length? What do you have for power?
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
Old 05-20-2005, 11:57 AM
Thanks
It has a 225 Mercury Optimax with stainless prop and the digital smart craft gauges.
2005 Sea Craft 23
Old 05-20-2005, 01:25 PM
Best of luck with your new 23’ you will love the ride and how it handles in the chop. I would check for leaks around the top of the live well after it is filled up. There has been some complaints that the live well is not sealed to the bottom of your deck and has caused some leaks into the bilge because of it. Your shake down run will let you know if there is any problems with the boat. I will be down at Calussa cove June 4th for a week with my 23 CC
FellowShip [img]/images/graemlins/wink.gif[/img]
Old 05-20-2005, 05:36 PM
Ntrain2k Ntrain2k is offline
[img]/images/graemlins/cool.gif[/img]
And they are only going to get better!
Glad you finially got it Luis, and if there is anything that I can help you out with, please don't hesitate to ask.
Oh, Did you get the link I sent for the SeaCraft apparel?
Old 05-20-2005, 06:17 PM
Ron,
Sounds like a step in the right direction. Keep up the good work.
Old 05-20-2005, 06:29 PM
Finster Finster is offline
I'd be interested to know what dramatic changes you've made?
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 05-20-2005, 08:17 PM
You will find that livewell issue a royal pain. My SeaCraft is a 2000 and the in deck well fills with water from everything: rain, washing down, etc. Every boat show I go to I tell the SeaCraft guys they need to fix this (offer a leaning post above deck well instead) and the access to the inside of the center console. These are the only two things I dislike about my 21.
