Old 05-21-2005, 10:03 PM
abl1111 abl1111 is offline
Default FYI : GREAT cleaner
Just used TSP ( Tri Sodium Phospate ) on my non skid as a booster for my boat suds - UNBELIEVABLE ! Makes regular boat suds turbo-like ! Buy at any hardware store for cheap.
Old 05-21-2005, 10:07 PM
Reel Smoker Reel Smoker is offline
Default Re: FYI : GREAT cleaner
Is that the name TSP? Who makes it? Does Home depot sell it? Thanks RS
Old 05-22-2005, 01:10 AM
amadaeus amadaeus is offline
Yes, home depot sells it in the paint department. works great when cleaning gas spills on the deck! this stuff works wonders!
later!
k-roc
Old 05-22-2005, 09:13 AM
RS RS is offline
Carefull, it's strong stuff. It will etch (dullen) many paints and plastics, including plexiglas. Left too long or too strong it will etch glass as well. I used to use it to prep surfaces to be painted.
Best regards,
Roger
1979, 20' Master Angler
Old 05-22-2005, 10:57 PM
SCSeacraft SCSeacraft is offline
I agree with Roger,strong medicine not quite as bad a oxolic acid but close.se la vi to any wax you might have had on the boat but its great for stains.
Old 05-23-2005, 04:31 PM
JAL JAL is offline
TSP chemically is tri-Sodium Phosphate, a very alkaline (high pH) material that is especially good for removal of light oils, greases, etc. It will damage certain plastics like plexiglass (acrylic plastic).
Oxalic acid is a milder acid (relatively speaking) with a lower pH, but is excellant on removing mineral stains, especially rust (iron) or tanins from certain water (brown dis-coloration).
Old 05-23-2005, 11:58 PM
I must be using just the right amount because it works wonders. Thx for the heads up on plastic stuff. I think that if you use it to clean, then wash it off, it will do what you want with no (-) effects.
Old 05-24-2005, 12:40 PM
Briguy Briguy is offline
Any idea if it will remove waterline stains from gelcoat or if it helps with slime or barnicles?
Capt. Brian
