Old 06-01-2005, 01:45 PM
blackfin29 blackfin29 is offline
Default transom trouble
I have a problem and I am hoping for suggestions....I recently bought a 76 CC with a blown motor, the boat seemed solid (floor and transom)I purchased a 140 suz. 4 stroke after it was installed I had a leak by the bolt hole....the boat yard that installed the motor just told me that the tran. is soft in that spot so the bracket bent, that's why I have a leak (they think it can be repaired by cutting the bracket and re gluing everything)....my question is this if I replace the transom (after the season)how do I deal with my brand new 20 inch Suzuki, I assume the correct thing to do is raise the transom, but then what?
Old 06-01-2005, 05:06 PM
Default Re: transom trouble
First question would be which size boat do you have?
[img]/images/graemlins/confused.gif[/img]
Old 06-01-2005, 07:38 PM
flash14 flash14 is offline
If they cut away the bracket and redo the transom, why can't they use the bracket over again to accomodate the suzuki? I'm assuming this is a 20' with a 140 on the back right? Show us some pics and we can help. Best of luck with it!
Old 06-02-2005, 09:39 AM
Abe's Rocket Abe's Rocket is offline
Would a soft transom really bend a motor bracket? Is there that much torque?
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 06-02-2005, 09:04 PM
Briguy Briguy is offline
Blackfin, We need more info...........
Capt. Brian
Old 06-03-2005, 09:22 AM
sorry guys I was away from my computer.....the boat is a 20 the soft spot is where the lower port side bolt goes through the transom.....the boat yard tightened and glued it up yesterday so the leak is gone, but you can see that the metal plate on the insibe of the transome is bent,from the bolt being tightened....I'm going to try to get through the season,but I have to do something this winter.
Thanks, Blackfin
P.S. the boat runs great with the 140
Old 06-15-2005, 10:42 PM
I have a problem....how do I deal with my brand new 20 inch Suzuki, I assume the correct thing to do is raise the transom, but then what?
Raise the transom to 25", extend the motor. Mercury and Johnrude make kits to convert a 20" to a 25", I would assume Suzuki does as well. The Merc kit consists of a driveshaft extension, shiftshaft extension, a longer water pump tube, and a 5" spacer that bolts to the bottom of the midsection housing, and to which the lower unit then bolts up. I bought one for a friend off of ebay two years ago for under $300. The original price was twice that.
Kepp the motor, extend the housing.
Fr. Frank says:
Currently without a SeaCraft
Old 06-16-2005, 09:58 PM
tomseafari tomseafari is offline
I've been planning the rebuild on my 20 ft seafari. I was told by someone that when they raised the transom the boat didn't perform the same.
Old 06-17-2005, 09:09 AM
Personally I can’t see why any one would tell you that the boat would not perform the same. Where the motor is located upward on the transom would not cause any difference it its performance. What it would do is KEEP MORE OF THE WATER OUT OF THE BOAT by 5” more transom height. On my 23 CC I have a 30” transom and that really works great.
FellowShip [img]/images/graemlins/wink.gif[/img]
Old 06-17-2005, 03:20 PM
nestorpr nestorpr is offline
The only other difference would be that the center of gravity would be raised a bit by the higher motor weight but I also don't see where that bit would affect performance very much.
Boatless again!
