Old 07-27-2005, 03:24 PM
Dunny Dunny is offline
Default TRIM TABS WON'T FIT
I have a pair of Bennett trim tabs that came with my boat that don't fit due to the bracket on the stern. Anyone know which model of Bennett trim tabs will work with reduced area to install them? Thanks, Dunny [img]/images/graemlins/smile.gif[/img]
Old 07-27-2005, 04:19 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: TRIM TABS WON'T FIT
It would depend on the bracket. Measure the area in question and take a look at Bennett's site for the tab that would fit the best.
Old 07-27-2005, 06:38 PM
Dunny
I don't know what size tabs you have but 12"x 12" Bennett's seem to be the most popular size for the 23'. Bennett does make different size actuators, so depending on your bracket type and at what height the platform is, will determine what size actuator would fit best. I have the SeaMark (Potter) bracket. I got the 10" actuator from Bennett. It was the smallest they make and I still had to notch the platform on the bracket. I think the Lenco brand trim tabs will fit under most brackets without modification. If you intend to utilize the Bennetts, I would contact Tom Mcgow at Bennett Marine for his advise. (tmcgow@bennetttrimtabs.com) You can also contact him with a PM thru this site. His user name is "TABMAN" [img]/images/graemlins/wink.gif[/img]
Here is a picture of my notched bracket and 10" actuators..
Old 07-28-2005, 02:23 AM
Fishjack Fishjack is offline
Capt Chuck - I noticed in your pic that your trim tabs are not flush with the bottom of the hull?? When I installed my 12x12s I mounted them just about at the bottom edge of the hull (about 1/8" up).
Is there a reason for this?? thanks Jack
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
Old 07-28-2005, 08:43 AM
I think it's just the angle of the picture...They are mounted flush with the bottom deadrise approx 1/8" up as recommended [img]/images/graemlins/smile.gif[/img]
Old 07-28-2005, 03:28 PM
Capt Chuck - yep that is an optical illusion... Your hull is so shiney [img]/images/graemlins/wink.gif[/img] it looks like the tabs are mounted high on the transom in that one stearn shot..
1977 23' Superfish
ST250x Yam
Old 07-28-2005, 05:45 PM
Fishjack
Remember it's the "Outer Edge" of the Tab that is up approx 1/8"- 1/4" up from the bottom of the boat. Not the mounting plate. As mentioned, I only used 10" actuators..You don't want the tab to be dragging when it is extracted. (up position)
BigMike
<font color="orange"> Does the potter bracket help trim the boat or does it seem make the trim tabs work harder?
I noticed it's hight above the bottom of the boat so at a plane do the tabs have to create more lift?
Being that the SeaMark bracket is a "Positive" Floatation bracket and "Parallel" with the bottom of the boat, there is minimal "Squatting" when out of the hole. Less tab use is the result especially at plane because the motor's prop is in "Cleaner Water".
Also your drain hole has been pluged on the transom do you recomend that?
My boat is kept 99% of the time on a lift. It would have been impossible to reach under the bracket and pull the plug to drain the bilge. The drain plug was drilled through the bottom of the keel up against the transom. Access is obtained through a transom door and a special handle/drain plug set up.
Old 07-28-2005, 02:08 PM
BigMike8o9 BigMike8o9 is offline
Wow, after seeing the picture of your boat I'm compelled to go out and work a little more an my boat before painting.What great workmanship.
Also that your drain hole has been pluged on the transom do you recomend that?
Sorry for so many dumb questions.
BigMike
www.bigmikeslures.com
Let me know if you want to sell the old ones. I'm not putting on a swim step.
bigmikeslures@aol.com
