Old 08-09-2005, 03:51 PM
benhardj benhardj is offline
Default Wiring Help
About to start a rewiring job on a 20' slickcraft center console. I am going with a Blueseas fused switch panel and was wondering what type of fuse or breaker I should use between the battery and the panel??
Old 08-10-2005, 01:49 PM
TUGBOAT TUGBOAT is offline
Default Re: Wiring Help
SlickCraft,
I went with a stereo Fuse holder? Was told it would work .have both batteries going thru 1 block with 2 fuse's.So far so good. Just coat everything w/silicone grease. There big so their easy to remove & replace anywhere.Hard o buy so keep eXtras onboard.Upper left side of photo. [img]/images/graemlins/cool.gif[/img]
Scream'n Reels'
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 08-10-2005, 02:24 PM
Thanks Capt. Brad. Do you know what size fuse you used? I'm gonna try to find one soon as I can.
Old 08-10-2005, 04:13 PM
warthog5 warthog5 is offline
I have the Blue Sea's 8 gang panel 8261
I would suggest that you buy a 8271 panel. This one has circuit breakers in it. It was not available when I bought my panel. The 8271 has only been out about a year.
Of corse they make them in lesser switched panel's too.
As to your imedeate question. you need to add up all the amp's of all the curcuit's that your going to run off the panel. Then jump it up maybe 20 more amp's to make way for any additional stuff that you may want to add latter.
Then install a Blue Seas Surface mount breaker beside the Master switch [ON/OFF/1/2] depending on how much amperage your going to push thru this curcuit breaker? A 8ga,6ga or 4ga cable will jump from the master switch out to the breaker and then foward to the console.
Old 08-10-2005, 06:59 PM
Like warthog said, i have i believe the same switch panel with this type circuit breaker coming off my battery switch-
http://www.iboats.com/products/377/1..._breakers.html
Old 08-10-2005, 08:38 PM
SeaMaster SeaMaster is offline
Look how Don did ours. http://hermco.net/gallery.htm Its the first doat on this page! [img]/images/graemlins/grin.gif[/img]
http://img.photobucket.com/albums/v7...6/582ba35a.jpg
1979 23 cc SeaCraft twin Yamaha 200 HPDI's
1999 16 Carolina Skiff
2006 4x4 Titan
Old 08-11-2005, 05:44 PM
I believe I have 40=50's, .Hmmm, It's been working great,I have brekaers on all the swiitches,but just may go the way all the above has done.Nutt'n like having MAIN breakers.Thats the best way.Water proof too.Not that I want to test that feature out! [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
