Old 02-26-2006, 03:52 PM
Default What every boat needs??
Just thought I would throw this out there to see what everyone else considers must haves while underway. I thought maybe this would be a good information source for people to share their inovative ideas, or best practices. So far I have ready a good tool kit with adjustables, tape measure, various wrenches, duct tape, electrical tape, pliers, spark plugs, nail clippers, various sockets, fuses, various nuts, bolts, washers, spare belts, flash light. I was wondering what you guys have for damage control gear. Or other things people would not leave home with out.
Old 02-26-2006, 04:57 PM
hermco hermco is offline
Default Re: What every boat needs??
Nail clippers?
Old 02-26-2006, 06:18 PM
dcobbett dcobbett is offline
A selection of zip ties, a spool of wire, a couple of wood plugs for any through hulls, a small, heavy duty tarp, a couple of different sizes of strap wrenches, short lenghts of various line/rope in varoius sizes (diameters), some gloves and a couple of grease pencils.
Old 02-26-2006, 07:39 PM
Yeah, finger nail clippers.
Old 02-26-2006, 11:44 PM
Guest
Posts: n/a
A can of spray foam and a plastic bag can do wonders in a pinch and tube of 4200 is also good
Old 02-28-2006, 08:48 AM
Sleeto Sleeto is offline
Scott,
Please tell us exactly how you would use the spray foam and plastic bag.
Thanks
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
Old 02-28-2006, 09:09 AM
Fresh drinking water? Or beer..........
Old 02-28-2006, 03:09 PM
nestorpr nestorpr is offline
Sounds kinky to me...
Boatless again!
Old 02-28-2006, 10:31 PM
Guest
Posts: n/a
Put plastic bag in hole insert spray foam tube into plastic bag depress trigger on spray foam can if all goes well spray foam will fill bag and hole then turn on bilge pump wait for water to leave boat or not and drive to nearest boat ramp and hope your truck and trailer are there. This will work on holes above and some spray foam will even expand enough under water if you can keep it in the desired location ie the plastic bag. I have used the two part expanding foam to float many boats successfully that had very large holes.
If you look closely you can see the tarp covering the hole in the front of this boat that was large enough to drive a small car through behind the tarp is 30 gallons of two part expanding foam we towed this boat 35 miles to the lift and kept it afloat with only one 2 inch pump.
Old 02-27-2006, 12:38 AM
TUGBOAT TUGBOAT is offline
AMT 45 !
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
