Old 05-28-2006, 01:51 AM
Default Prop suggestions 20MA
I just bought a 20 MA and the standard Merc prop is lame, the motor is high, the current prop is a standard Merc SS with almost no cup, 5600 WOT but also no bow lift at all and it breaks loase easy. Need a prop with longer blades and cup as I had my V8 jacked high and had the same problem with OMC SST props. There are just so many new props out there, any suggestions?
Old 05-28-2006, 05:30 PM
Default Re: Prop suggestions 20MA
Eggs - What HP merc are you running?
See if you can find a place that will let you try out the props before you buy them. I really liked the HighFive on my MA. That prop likes to run high. I have a 19 Mirage Plus and a 21 Merc Offshore that I'm going to try out this afternoon. I'll post some numbers.
Old 05-30-2006, 03:14 AM
The Mirage Plus 19 is the fastest so far. 50.8 mph @ 5800rpm.
The Mirage Plus 17 tach'd out at 6000/6100rpm 49mph.
21 Mercury offshore couldn't spin over 5000rpm w/ the 1.87 gearcase.
Old 05-31-2006, 01:47 PM
Eggs there are three other props I'd like to try someday.
Merc Laser II 19
Merc Tempest Plus 19
Merc Enertia 19
The Mirage Plus is a great prop . . . More vibration that the 4 or 5 blades, but very very nice. The prop gives the boat the perfect ammount of lift and the ride doesn't get squirelly at high speeds . . . like the Michigan Rapture (which I hated). It holds pretty well in the turns too.
Old 05-31-2006, 01:53 PM
Its a 200 XRi sorry pretty stupid
Old 05-31-2006, 07:45 PM
what's the pitch on your current prop?
