Old 06-08-2006, 10:16 AM
mbo_1971 mbo_1971 is offline
Default Tabs on 20SF w/ 200 HPDI - Size & lenco vs bennett
Just picked up a new motor for my long term project '84 20sf. It is a 200 HPDI with 200hrs - very excited. Thinking about trim tabs - are 12 x 12's overkill on the 20 footer? Also, I would rather not have to deal with the hydrolics of the Bennett's - any major downside to Lenco's? Thanks.
Matt
Old 06-08-2006, 11:01 AM
captj2 captj2 is offline
Default Re: Tabs on 20SF w/ 200 HPDI - Size & lenco vs bennett
I just installed Bennett M120's on my 1978 20"/ 200 hp Merc. and could not be happier. The installation was quick and simple and the control is amazing. We ran the boat 150 miles in the keys on the first trip with the tabs and I am sold.
There is no reason to be concerned with the hydraulics. I mounted the pump in the CC well away from any possibility of contact with salt water and mounted the tabs a bit outboard of what Bennett recommends. Check out Capt.Brad's installation photos
The hydraulic lines were easy to snake through the bilge to the cc. I am not familiar with the Lencos but I do not trust electric motors in that close contact with salt water. I can tell you that the customer service from Bennett is the greatest. They maintain a presence as TABMAN on another forum and supplied me with extended hydraulic lines and a surface mount for the pump without charge. They even paid for the shipping!!!
No I don't work for Bennett but when you find a product this good and a company this supportive, they deserve recognition.
Capt.Jim
Old 06-08-2006, 11:24 AM
Bennett's are the only tab I would ever use.
When I bought my '70 20SF in 1984 it had 24 inch tabs on it.
They are the only thing that was reused when the restoration
was complete. Go with what works---FOREVER!!
See ya, Ken
Old 06-08-2006, 02:23 PM
JW-Tex JW-Tex is offline
If you do the research on other boating forums...you will find that Lenco is second choice by a longshot.
Based on my research I would not install anything other than Bennett (too many electrical failures on the Lencos).
I recently installed the Bennett M120's on my 20.
Moesly 1969 20 CC & Potter 1978 23 CC (23 in storage awaiting rebuild)
Old 06-11-2006, 12:02 PM
Another nice thing about bennett tabs is that you can replace the lines (if you need too) for about $10 using regular compression fittings and black irrigation tubing from the hardware store.
Old 06-15-2006, 04:57 PM
alarie alarie is offline
I have used both brands, currently using Lenco's which were a lot easier to install, but I have only 1 season on them. The M120's on my last boat worked very well.
I would recommend mounting the trailing edge higher than the 5/8" (or whatever the number is) that is recommended in the directions. I find that going down swell it is nice to have them fully retracted, and always felt that the stock setting did not allow enough clearance for this. I would go with 3/4-1" of negative trim at installation.
By contrast, it also seems like you never put them down very much with that hull, so adjustment range will not be a problem.
Peter Alarie
"that won't take too long, will it?"
alarie404@mac.com
