Last night I spent an hour looking around the hull. All looked good but I was unable to access all that I wanted since the boat was at the dock and the outboard was tilted up.
Everyone suggested that I check the transom but could not do an effective job due to motor. Saw no stress points on the transom glass inside or out. More work to be done here when it is out of the water The screws that attach the console to the floor boards, 90% have spider cracks and the front attachment area is badly cracked around the lip. Does this this indicate anything other then it is a 18 year old hull? Hull looks to be in good shape so the motor and repower cost is the big factor unless you guys tell me I need a litle more checking. On my list when it is on the trailer is; 1) Gas tank 2) transom 3) Thru Hulls 4) trailer strength 5) have the 1989 225 checked out Will try and schedule sea trial next week. Any suggestions on what to feel for or test while under way? Photos to follow as soon as I have the cd. Tks KE7GCJ |
Another question,
When viewing the repair and modification pages I saw the foam from one hul needed to be removed because it was soaked. Is there a good way to check this out? KE7GCJ |
I missed it but which hull is this?
From what I gather most Potter built, including mine do not have much foam in them unless it was added later (except in the stringers). Check the brass drain plugs, stern and forward fish box. Hope that helps.
May all your deadrise be variable. My 1973 SeaCraft 20SF Parker 2530 DVEC Boston Whaler 15 1984 |
