Old 07-18-2006, 07:22 PM
Lenny Lenny is offline
Default I cant help but think to myself
I have everything out of my 20 CC I/O minus the outdrive housing and I can't help but think how easy it would be to drop a bracket on it once the transom is done.
Could I make this work with a new Etec 150??? I plan to drop the tank in the floor and push it forward. Whatta ya think???
Under the knife 1969 20 CC I/O
Old 07-18-2006, 09:49 PM
Default Re: I cant help but think to myself
How is strong is the transom now? If it's solid patch the hole . . . get a bracket, use tank in the console, and go boating for the remainder of the season.
Save the rest for the long cold winter . . .
Old 07-19-2006, 08:20 AM
I thought about that but chose to do the right thing 1x, the boat is gutted and I need to come up with a plan before I go any further. A bracket with an outboard sure would be easy, just unsure of the weight distribution, and what would I do with all that space in the back On the other hand I like the lines of the I/O too, ahh decisions
Old 07-19-2006, 09:44 AM
klaucke klaucke is offline
I have a '72 20' CC w/ I/O, which I upgraded to an Alpha One engine and outdrive. I like it, still have four stroke reliability, good gas mileage, easy to work on, parts are readily available, etc. For me, I didn't think it was worth it to convert to outboard, which I considered.
I have been told the brackets + outboard are the best set-up for manuevability, top speed, etc. Its not that big a deal to me to justify the cost.
Putting the tank under the floor is a good idea, though. I wish I had done that to mine last summer when I replaced the floor, I even have a tank to do it with, but it just didn't occur to me at the time! With the tank under the floor, you can use a smaller console, which I think is key.
72 SeaCraft 20' CC | 2.5L Alpha One |"Two Dogs"
65 StarCraft 21' Alum. CC
Old 07-19-2006, 10:15 AM
jongolds jongolds is offline
besides the extra deck space the OB will let you in to more shallow water too. I always hated that I couldn't trim my old IO completely out of the water. Actually though now that I mention it my bracket is either too short or my engine to tall but, I can't completely trim this OB out either. I can get it nearly out though. Certainly high enough wher it's no longer the low point draft wise which is what always bothered me with the IO.
If you store the boat at all though, keep in mind how much longer the bracket will make you. They charge you for that.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 07-19-2006, 11:02 PM
nestorpr nestorpr is offline
My Alpha One tilts up more than enough to push my boat in skinny water. In fact, if you look at my boat's pictures in the main page you can see that she's sitting in about a foot of water with the drive tilted completely up. My brother even thinks he can go bonefishing in her when he comes visiting but I think that might be pushing it a bit!
Boatless again!
Old 07-19-2006, 12:55 PM
What about the Mercury/Cummins 1.7L 120hp diesel? If that fits into your boat . . . that's what I would do!!
http://marine.cummins.com/attachment...1.7/BC9013.pdf
Old 07-19-2006, 05:57 PM
I am going to look into that as well, depending on price and weight
