Old 07-26-2006, 03:22 AM
Default Suzuki 250 4 stroke
Well the timing was finally right so I decided to take the plunge and do the most expensive up grade you can do to your boat... buy a new engine!
My brother works for a crane company so we mounted it at his shop. You may notice that these are the same two guys that are in the fishing pic's I posted a while back. I set them up for this little task by taking them fishing. The motor arrived and in less then 2 hours we had it bolted to the boat. It's going to the local dealer next Tuesday to complete the rigging. Here's some boat porn.
motor in crate:
the rigger:
at home:
Old 07-26-2006, 04:49 AM
warthog5 warthog5 is offline
Default Re: Suzuki 250 4 stroke
Why is the vent out of the port side?
Old 07-26-2006, 09:27 AM
plastic cheap vents that keep breaking at the dock. I'm going to have some custom ones welded when I get the chance.
Old 07-26-2006, 08:19 AM
The ultimate combination!!! Please post performance #'s when you get them.
Old 07-26-2006, 10:32 AM
Pretty soon you are going to run out of things to do on the boat and will be forced to just go fishing ALL THE TIME instead.
How’s that bracket holding up? From the pictures it still looks pretty good and solid.
I filled in those holes with glass and solved that problem.
Enjoy life is short.
FellowShip
My motto: Just for the Grins
Old 07-27-2006, 02:31 PM
Thanks guys
Fellowship- the bracket is holding up fine. I retightened the bolts when I took the old engine off the other day. Hopefully the new zuke wont take a dive into the drink on her first test run!
Old 07-27-2006, 03:11 PM
FellowShip
Fellowship - Just ask Strick if he found another Seacraft to work on yet. . .
Old 07-27-2006, 05:02 PM
I have that same motor and you are going to love it! They dyno out to 268 hp and they use all of them on the cheap. Propping is the key as is with any motor. Mine is swinging a 23p Mercury Revolution 4 and still bumping the rev limiter with a light load. Large diameter and blade width is key for the tall gears in these big Suzies. Good luck.
Old 07-27-2006, 06:38 PM
Sleeto Sleeto is offline
What kind of boat are you running your motor on?
Paul, 1989 23' SC CC 250 hp Suzuki Four Stroke on Stainless Marine bracket
Old 07-27-2006, 09:48 PM
1974 24' FleetCraft Express. It is a splash off of a 24 Formula. She is probably not quite as heavy as a Tsunami, but close with similar deadrise. Loaded with tanks, ice, and dive gear she can hit 47 knots and at 33 knots she gets close to 2.2 gpm nautical. http://www.classicseacraft.com/forum...0252#Post40805
