Old 08-24-2006, 03:57 PM
Kmodi9 Kmodi9 is offline
Default MARINE INBOARD VS. REGULAR SMALL BLOCK
what is the difference between a regualr small block from a car/truck and a marine one? Thanks!
Old 08-24-2006, 04:04 PM
Default Re: MARINE INBOARD VS. REGULAR SMALL BLOCK
the basic blocks are the same as far as I know......
however, the gaskets are marinized as are the electrics
to prevent sparks that could ignite fuel vapor (alternator,
starter, distributor, ignition).....and the air intake uses
a flame arrestor for the same reason. Things like power steering, seawater pumps, remote oil filter kits are somewhat different too.....
Old 08-24-2006, 04:33 PM
nestorpr nestorpr is offline
The camshaft and intakes are also different since the power curve for an engine used in a road vehicle and one used in a boat are completely different.
Boatless again!
Old 08-24-2006, 05:18 PM
thanks!!!
does anybody know what rpm range an inboard 23 wants to live at?
also any opinions out there or carbs vs. efi?
Old 08-24-2006, 10:20 PM
wot should be 42 to 4800 rpm's. i cruise mine at 3 to 3200 rpms for optimum fuel /speed - i have a friend with a 350/320 efi on his formula that really honks. I have a 350/270 carbed that does well also. Gary (Knot working) on this board also has efi and his boat runs right along as well.
Old 08-25-2006, 11:25 AM
oldbluesplayer oldbluesplayer is offline
a couple more things - first - I'm gonna guess we are talking about the ubiquitous 350 chevy small block -
if that's the case, the basic 350 block comes in two versions, the difference having to do with the number of bolts holding the crankshaft bearing caps in place - they are what is referred to a 2-bolt, or 4-bolt, mains. The 2 bolt mains are the common car variety blocks. The 4-bolt mains are used on the heavier trucks, and the high output motors like the Corvette - these are also sought after by drag race guys, as they are much stronger.
To my knowledge, the blocks that are diverted to marine industry use up front, ie. that go to Mercruiser et al, are all 4-bolt mains blocks, to provide increased reliability - the typical boat useage does place a higher continuous stress level on a motor - cranking along at 3000 to 4000 rpm for long periods under load, where the average car use would be floating along at 2000 rpm, under a lighter, rolling resistance, loading.
Also, for the 350 small blocks, depending on the vintage, as these have been around for half of forever, there are a variety of heads available, depending on carburated, or FI, and these contain different configuration intake and exhaust ports, and often different sized valves, from each other - the high output Corvette motors, for example, use different heads than a sedan or station wagon motor.
Along with all that is the already mentioned camshaft differences, and the marinized electrics, starter, distributor, etc.
hope that helps some.
Bill
