Old 09-15-2006, 01:50 PM
schmellenj schmellenj is offline
Default 1988 (not definitely sure of year) SeaCraft SF 20'
I just bought a hull and I am trying to power my boat. Is the outboard shaft line 15", 20" or 25". In addtion, what would you suggest to power the boat? Thank you
Old 09-15-2006, 02:08 PM
Rich Rich is offline
Default Re: 1988 (not definitely sure of year) SeaCraft SF 20'
Usually on the 20' Seacraft the transom takes a search" shaft. Also a lot of 20 owners on this site like the new Search outboards, they have been pissah!
Cape Marine Supply
Old 09-15-2006, 06:43 PM
Old 09-16-2006, 06:42 AM
EagleOCNJ EagleOCNJ is offline
I dont know either?????
Old 09-16-2006, 01:04 PM
Jon G Jon G is offline
You need to measure the transom to see if you have a 20 or a 25" transom, I'm not sure of what year they went to the taller one since thats a later boat, The last two digits on your hull ID number that you will find on the transom, right side top will tell you what year it is. Lots of choices for power, kinda depends of what you will be using it for. Running light all the time you can get by with less, wanna go fast with a heavy load? then more is necessary. The Yamaha 130 two stroke comes to mind, along with the Suzuki 140 four stroke as favorites for a good performance/fuel economy balance. If gas money was no object I would have a E-Tec 175 on my boat just so I could go 55 when I wanted to, but gas plays a big part in my budget nowadays and my 140Suzuki lets me run the boat as much as I want its so good on fuel, but I traded that for a low 30's mph top speed. Lots of things to consider when re powering.
Old 09-16-2006, 02:53 PM
Ikan Besar Ikan Besar is offline
If you re-read the first reply it makes perfect sense: SEARCH! These questions have been covered nearly as often as "where do I get replacement SeaCraft decals". (yeah, you can use the SEARCH function for that answer as well ).
Old 09-16-2006, 08:10 PM
"SEARCH THIS"
I quess you will have to excuse uz' dumb crackers,
we jus alittle slow somtimze.
Cea ya, kEn
