Old 12-17-2006, 12:01 PM
fishingjoey fishingjoey is offline
Default battery switch
I am going to be installing a battery switch into a 1986 23 seacraft that I just bought. How should this be done. What size model etc, do I need to do a job like this. Also I was thinking of just changing the bilge even if it works I think that putting in a new one may be the way to go.
Old 12-18-2006, 10:51 AM
warthog5 warthog5 is offline
Default Re: battery switch
You left out a bunch of imfo.
How many motor's? How many batteries? Do you want to charge the start battery and the house battery at the same time?
This can be a simple install or much more elaborate.
This is the last one I did in a Mako 20.
It has a start & house battery with a single DT-140 Suzuki. The batteries were moved into the console.
Old 12-18-2006, 12:33 PM
dcobbett dcobbett is offline
warthog5,
Did you ever draw up a diagram for the system? If so, can you post it?
Old 12-18-2006, 06:19 PM
How about this? I made the size bigger than normal so it could be read easy.
The wire size going to the Power Post/Buss Bar's & Fuse box is sized to handle the load that need's to go there. In this case I used 8ga along with the 30amp breaker.
The ground small ground wire comming from the bottom of the ACR is 14ga
Old 12-18-2006, 06:27 PM
You beat me to it Wart,
Here is the link for Blue Seas
See ya, Ken
Old 12-18-2006, 06:46 PM
Damn! I wished I'd found that before.
I still haven't found that new ACR online anywhere.
This is the original one that they came out with.
https://resources.myeporia.com/company_57/6330.pdf
If you look at the instruction's there they tell you to use Big fuse's. I like CB's. I also put 150amp CB's in that system. Maxed it out.
I didn't like the idea of the remote combiner. It wouldn't handle the amperage that the one I wired will. The cost is cheaper too.
It's really a simple to operate system.
When you ready to operate the boat: Turn the Motor & House Master switch's on. That's it.
Leave the combine switch in OFF, unless the start battery is low and will not start the motor. Then turn the Combine ON/OFF switch to ON. After you start the motor, turn the combine switch to OFF.
Here's another deal about these ACR's.
They will pull a small amount of power from the batteries when All the switch's are off. Where talking mA. Check the product manual for "Power consumption"
You can trip both of the 150amp breaker's and it will stop that. Or there are other way's to wire the CB's in the system by picking up the power on the far side of the ON/OFF switch's, instead of at the battery post's.
When those Master switch's are OFF it would kill the power consumption from the ACR.
If the boat sat unused for a month the battery would be down a little.
But that may be a problem with where the 30amp breaker is in the circuit now. Just tripping the breaker's is pretty easy and easy to reset when you turn both master switch's on to use the boat.
