Old 01-17-2007, 01:32 PM
Solafide Solafide is offline
Default Good fiberglass shop in South eastern Ma.
I recently laid out plenty of cash for an Armstrong double wide bracket with a swim platform only to find out that my origanally sterndrive transom in slightly bowed outward and the bracket will not lay flat against it.The transom is very thick and rock solid,does any one know of a shop in south eastern Ma. that could make a modification to make this work? Thankyou
Old 01-17-2007, 02:10 PM
Ed Ed is offline
Default Re: Good fiberglass shop in South eastern Ma.
My first recommendation would be to see if you could return the bracket to Armstrong and have them issue you a credit toward a bracket designed specifically for your boat.
If that is not possible, there are several good fiberglass shops on the south shore who do nice work.
Custom Fiberglass in Hingham: Ritchie Doyle
Metan Marine in Norwell: Mike Borelli
There is also another guy who is a member of this board and runs a shop down on the Cape. I believe his companies name is Offshore Systems.
Old 01-17-2007, 03:01 PM
Armstrong will not take the bracket back.I thankyou for the suggestions and will look into them
Old 01-18-2007, 02:37 PM
kerneltugboat kerneltugboat is offline
Contact John Strome at Strome Marine, 508-527-0499 on Great Western Road in Dennis.
He has a small shop with low overhead, John did my 27 , including the transom, it is on Meetinghouse road in Chatham if you want to see his handi-work. He has a yellow 23 in his shop right now, which he just finished the transom. He has done a ton of Seacrafts, and can do anything with glass. I am sure he can help you out, he will steer you in the right direction, even if it is better to modify the bracket rather than the boat.
Good luck,
It's not a Small-Craft, it's a Seacraft
