Old 02-14-2007, 06:24 AM
elvspec elvspec is offline
Default '89 Seacraft
I have an '89 20' CC Seacraft and I have to say I'm a bit dissappointed in it's rough water capabilities. It is an extremely wet ride which sucks but I can handle that. My biggest concern is that in 2-3' seas I'm afraid to anchor because the boat takes water over the bow. Their is no excessive weight forward so I'm confused. My question is is the hull design different on this year boat then on earlier models and models being produced now? When I look at photos of the older models they do seem to have a bit more freeboard. Is this an optical illusion or delusion?
Old 02-14-2007, 07:01 AM
Default Re: '89 Seacraft
I would find a truck stop with a scale. Weigh the whole rig.
Make note of how much fuel you are carrying as well.
6.5 lbs. to the gallon for gas. Note your water line when at rest. You may have a water logged hull. Do you have trim tabs? Due to the fast entry of these hulls, it is possible to stuff the bow. What size engine do you have? Where are your batteries locatated? Do you have a fresh water tank forward in the bow? Water 8.33 lbs. to the gallon.
Post some pics of your boat. One of us may pick up on something from them.
See ya, Ken
Old 02-14-2007, 11:15 AM
Spray rails might help....
Old 02-14-2007, 03:27 PM
I'll try weighing it but would be surprised if it is water logged. The boat jumps out of the water and even with the 150hp I have on it it's clocking out at around 43 mph. Trim tabs might help the front end under power but will do nothing while at rest.
If the boat is water logged whats the remedy besides pulling the cap and floor and redoing it?
Old 02-14-2007, 10:21 PM
Just a couple of thoughts here . . .
Prop . . . You can try a different prop. Some props give better lift in the bow.
Has the console been moved forward?
Where are the batteries? (mentioned above)
Where does the cavitation plate line up with the bottom of the hull?
Anchoring in 3ft chop . . . is a bad idea all around in a 20ft boat. If you are doing this let out lots of scope and clip off to the bow eye instead of a cleat.
Also trim tabs won't help you get the bow up.
Old 02-14-2007, 03:31 PM
Also, I did have a full tank of fuel which I believe is around 70 gals. BUT, that is aft to rear and if this is supposed to be an offshore boat it should be able to carry that much weight w/o a nose dive, right?
Old 02-14-2007, 04:34 PM
I know this may sound stupid, but we have a CSC member that
just bought a 70's 20SF that when he sea trialed the boat he trimmed up the motor. The "original" owner was riding in the boat when he did that, and the owners reply was, whats that! The poor guy never realized that it had TNT.
I also agree with ScottM. The more scope out will soften the bounce.
Remove a screw from the transom, IE: transducer, speedo,
etc. If water comes out, Uh Oh!!
Also, put a bucket under the drain plug after you come
back from a trip, jack the tounge up, If water comes out for days you have a bigger problem. Open up all inspection ports check underneath the covers for moisture or mold.
Good Luck, Ken
Old 02-14-2007, 10:25 PM
Beau - That hull didn't win 186 and 500+ mile offshore ocean races diving through waves. Cut it . . . with the tongue and cheek remarks and you'll get a better response.
Old 02-15-2007, 12:38 AM
Bishrimpin, don't know which part of my post you are responding to as being tongue and cheek. I am being sincere about my effots to resolve a problem. If it was the comment about wanting to test ride someone elses seacraft I'm being honest. I'd like to do a comparison. I had heard nothing but good about these hulls which is why I picked one up in the first place. Don't get me wrong, the boat has a great ride and is quick with even a 150 on it as I mentioned which I originally thought was going to be underpowered. I was surprised. If it is the comment about this boat being able to perform in an offshore condition with a full tank of gas I mean that as well, but I don't think that is the problem. Hope I didn't offend anyone just trying to get some critical answers. Thanks
Old 02-14-2007, 12:53 PM
I agree with No Bones . . . There's something wrong (i.e. - water in the foam under the deck).
