I'M a new boat owner, just purchaced a 76 seacraft.i'm having a problem with my well,durring the process of installing the well i relealized the deck level is lower than the water level outside boat .how can i get the water in my well to drain?
which model, is this an in floor model?
not sure on the model ,but it is in the floor.
You will probably have to use a pump on the drain to pump it out. If you run it to a thru hull above water line it won't back flow in. If it is at or below water line you might need to add a check valve inline.
The first question is where did you install the bait well? Second question how much weight do you have in the back?
I have a 23’ 1976 CC and moved it forward to just in back of the leaning post seat. Plus I installed a deck for it to sit on same height as the gas tank platform, then I moved as mush weight forward under the center consol plus one motor on the transom then I cut a drain hole approx 3” maybe even more from the top of the tank and drains out the back close to the bottom of the V of the transom. I don’t get water overflow unless a bait fish gets stuck in the drain. I also have a sealed deck hatch kept close unless I am putting in or taking out a bait. With all this the water level is almost up to the deck but it doesn’t overflow. ![]() FellowShip _______________________________________________ My motto: Just for the Grins ![]() |
My i/o has that in-deck baitwell right about where fellowship has his but I've never gotten up the nerve to plumb it. I sure would like to, but that big drain hole in the bottom of the transom scares me a little. Does the line have a check valve in it? Does it have a shut-off to manually seal the line?
I've often thought that I should just put a portable on deck, as I don't do too much live bait, but that's surrendering even more deck space than thei/o already takes up. |
I have a cut off on the intake scoop where the bait pump pulls into the tank and on the exit I have brass through hull with thick hose and two clamps on both ends holding it together.
Holes in your boat are always a concern but really holes are not the problem poor connections, poor maintains, and bad bilge pumps are. I have one scoop, one transducer big football size hole, one drain for the boat and one for the live well now I am thinking about 2 underwater lights. Some boats look like a swish cheese now a days with all the stuff they are putting in them. O I forgot my ducer has a hole in it for the temp and MPR paddle as well Plus that hole in the front of the hull for the drain in that fish box. FellowShip _______________________________________________ My motto: Just for the Grins ![]() |
