Old 03-31-2007, 10:12 PM
Ryank Ryank is offline
Default FIRST RUN!!!
Finaly got my 23 savage wet and had some fun today! Per the gps and navman she is cruising at 4100 rpms at 30 mph burning 12 gph, pretty much anywhere I run it except dead idle burns about 2.5 - 2.75 gph. Not great but not bad considering the ride is INCREDIBLE!!! She handles 2-4's with no pounding and rides as smooth as good as my 29 whaler did. Silly me mounted a small backup color fishfinder in a location that keeps me going past 3/4 throttle So the most I can hit is 4900 rpm's I feel confident I can hit about 5500rpms but think I need to drop from a 18 pitch 4 blade down to a 17 pitch.
We also saw a Beautiful 23 Blue CC Seacraft with Twin 150' yamis on the back not sure who she belongs to, but was a beautiful classic!!!
Seacraft's for life !!!
Old 03-31-2007, 10:36 PM
Default Re: FIRST RUN!!!
Hey Ryan....did you build the savage from a Sceptre??
I'm going to call you on those windshields....but getting there to get them is giving me a challenge.....
Old 04-01-2007, 07:02 PM
Yes it was a Sceptre in its first life. No problem let me know on the windhsield and stuff.
Old 04-01-2007, 10:06 PM
bbh57 bbh57 is offline
Sounds good, Cant wait until I can take that first ride in mine, but still so much to do. Went offshore in my Sportcraft last weekend and got bumped around a bit in much lighter seas than you were in.
Old 04-02-2007, 08:34 AM
Just a quick question, How can you tell if your motor is too high on the bracket? Will your boat seem to run lower in the water? I can only trim the motor for a second or so before it starts to cavitate. I am on top holes on the bracket, and measured properly for the set back to cavitation height, I was originaly concerned that the engine was to low but it may be the reverse now. Any ideas?
Old 04-02-2007, 08:47 AM
doug7488 doug7488 is offline
Sounds like the engine may be to high. Alot depends on the type of prop, but typically, if you can't trim the motor up w/o cavitating, it might be to high. Does it cavitate while turning on plane?
