just baught a '77 hull no motor. everything is solid it has a 20" transom. Should i raise the transom 5" or close it and put a bracket? I have experenced a 20" transom and find it to a little wet inside. What size motor will give enough HP but not change the waterline?
I have a '75 20'SF and have not raised the transom - I found that any motor under 375 lbs. and moving the oil tank and battery forward will keep the waterline high enough to avoid wet feet. In order to get a motor that light generally requires a 2S 4 cyl. motor - 130 hp works well at about 350 lbs. and will move the boat at about 40 mph. I have a 2003 carbed 2S 175 hp Johnson that weighs 385 lbs. and will move the boat in excess of 50 mph.
Congrats on the purchase!
Assuming that you may have to rebuild a 30 year old transom and have not yet picked out an engine, I really can't see the benefit of not raising from 20" to 25". I nursed along my original 20" 1969 transom with a jack plate as long as I could and since the rebuild have no regrets having the extra 5". Now I have fewer worries of too many people crowding the stern or taking a wave when backing down. Not sure what size boat you have but I think the bracket issue is a matter of personal choice - hopefully others will chime in. I considered it but thought it might negatively affect the performance of a 20SF. I could not be happier with my setup of a 130HP 2S Yam on my 25" transom. Best of luck with your decision.
1969 Seacraft SF20 / 2003 Yam 130 "And the sea shall grant each man new hope. . ." - |
