Old 04-22-2007, 06:21 PM
peterb peterb is offline
Default ADJUSTING TRAILER FOR 23' SF
I bought a new trailer this sping for my new old 23' SeaCraft. It is a tide water roller style. Anyway my new boat has twin 200'S (see attached picture)_ and a bracket on it. That's a lot of weight in the back.
[/image]
As a result the trailer has no tongue weight and starts to fish tail pretty bad once I hit 50 miles per hour. I have been advised to slide both axels back around 9 inches. I have never done this before and aim to tackle it one day this week. I was just going to loosen the nuts and take it from there.
Are there any specific tricks to do this? I would greatly appreciate any insights that you can share with me.
Thanks,
Peter
Old 04-23-2007, 02:06 PM
Default Re: ADJUSTING TRAILER FOR 23' SF
Peter,
1st, jack up the trailer in the back, at least 6" AFT of where you intend to move the axles. Do NOT let the wheels come off the ground. Put two automotive-type jackstands in place AFT of the jacking point, one on each side of the frame.
Next, jack up the trailer frame about 3'-4' FORWARD of the current axle placement. At this time, jack the trailer up so that all the tires come off the ground by about 1/2" to 1". Block-up or jackstand the two forward points as well. Try to do this so that your trailer frame is very nearly level, with the tires just off the ground.
At this point, your boat and trailer should be level, supported in four places, with the tires just off the ground.
Loosen the rolling carriage at all mounting points, so that the tires are now supporting all the un-sprung weight , and using the tires, with you and an assistant on each side, now ROLL the axles and carriage backwards to a pre-measured point AFT of your current point. 9 inches should be close to what you need. Make sure both sides move the same distance.
Now LIGHTLY tighten your carriage mounting bolts, then gently take the trailer down off the stands, and weigh for tongue weight. If you have the magical 5-7% of your gross weight, tighten everything up the rest of the way and your done.
Fr. Frank says:
Currently without a SeaCraft
Old 04-23-2007, 02:09 PM
Trayder Trayder is offline
Velvet Jones
Does the place you purchase the trailer at offer a service to fit your boat to the trailer?
Its a real pain in the arse to move axles around but due to the fact you trailer is new it will be easier.
The places our here that sell trailers charge a couple of hundred to fit the boat to the trailer.
If you are doing it yourself buy borrow or steal a compressor and impact wrench.
Old 04-23-2007, 09:45 PM
Thanks Father Frank and Jason.
Quick question. When I do this should the trailer be attached to my SUV (so that there is no unnucessary movement)?
Old 04-23-2007, 11:20 PM
First of all
No.
Second, I agree with Jason about the impact wrench. It will save a lot of time, AND provide for greater security. Or, if you're the he-man type, just put a 3' pipe on the handle of your 1/2" drive breaker bar, and good luck loosening those nuts
Fr. Frank says:
Old 04-24-2007, 09:14 AM
I have always drooled over those impact wrenches and compressor setups. My next door neighbor is a big time gadget guy. I will see what he has.
thanks
Old 04-24-2007, 11:23 AM
klaucke klaucke is offline
I agree it is much easier to adjust the trailer w/o the weight of the boat on it. Moving the axles is a pretty easy, straight forward job once everything is in position. If you live near some water, I would look into just dropping the boat into the water and leaving it tied up somewhere, if you have access to that sort of thing.
Once you have everything jacked up (either w/ the boat or w/o), you only need to remove the bolts and move them back to the desired mounting holes. Please be very careful that the trailer is properly supported w/ back up in case a jack stand fails, etc. Some blocks of wood or spare tires are cheap insurance!
72 SeaCraft 20' CC | 2.5L Alpha One |"Two Dogs"
65 StarCraft 21' Alum. CC
