Old 05-12-2007, 03:34 PM
osprey osprey is offline
Default new wiring- grounding plate
I'm re-wiring my 23cc and am wondering about a grounding plate or strap as I have heard it called. I can not find one anywhere in the bilge. Just wondering if boats this size should have one. I'm in S.W. Florida and the summer storms get crazy down here. Just replaced my fuel filler hose and there was a wire for grounding the filler going to nowhere. I guess I'll run a new wire and connect it to the sender. Just wonder what eveyone else has done for lightning protection. I also need to put a new vhf anteana up, not sure if I should get regular or extra-crispy
Old 05-14-2007, 02:43 PM
Default Re: new wiring- grounding plate
I take that no one else has a grounding plate either!
Old 05-14-2007, 02:58 PM
I attached my green wire to my brass water pick scoop then ran it to my CC and then attached EVERYTHING to it including the gas tank and the T-Top. Your outboard motor has one as well but I figured that’s not a good idea just incase of a strike.
FellowShip
My motto: Just for the Grins
Old 05-14-2007, 06:04 PM
in Florida, the lightening capital of the world, grounding plates are ABSOLUTELY ESSENTIAL!!
Here's a link: Grounding Plate 8"
and on ebay: Grounding plate
Fr. Frank says:
Currently without a SeaCraft
Old 05-14-2007, 07:08 PM
GroveGuy GroveGuy is offline
Someone please elaborate on this setup. No T-Top on my boat, and I have been fortunate enough over the years never to have had any close calls but you never know.
I guess the thunderstorm outside right now is motivating my concern...
1969 Seacraft SF20 / 2003 Yam 130
"And the sea shall grant each man new hope. . ." -
Old 05-15-2007, 10:25 AM
Grounding plate are boat lightning rods. Your wanting to divert the current out of human’s harm way and diffuse the current. The grounding plate is the way to go but on most trailer boats not to many people install them. Your outboard has a wire attached to it to use the lower unit as a exit but that will not keep you or your electronics safe. By attaching everything to the under water bait pump scoop “at least you are directing the potential surge”. You are not diffusing the charge just hopefully directing it from harms way. With a 8’ beam boat having a lot of stuff under the hull that can causing cavitation to the props can be a problem plus you want to allow a fork lift and your bunks free access to the bottom especially if you ever need to have a forklift lift up your boat from your trailer. Another issue is they will cost you approx $100. not that much but I ask my self do I really need it?? kind of like insurance. If you needed it it’s already to late in get it. I don’t like being in thunder storms on boats and I will pull the plug and call it a day if this becomes a issue, plus my re direction of current to a safe exit is just another minor project and makes me feel a little better. I know it’s not the best but if I ever get Zapped my bet God must have a SeaCraft in heaven for me to mess with.
FellowShip
Old 05-15-2007, 02:27 PM
What gauge wire would you use to divert to the scoop.I don't know the dynamics of the electricl charge of a lightning strike, but all that juice must be able to fry the insulation off . thanks for the responses. I was starting to think no one cared about me
Old 05-15-2007, 02:31 PM
It is called bonding the hull. Fr. Frank posted several
links to get them. The bigger the better. All metal objects,
IE: Grab rails, T-Tops, rod holders, cleats, etc, etc.
should have an insulated tin coated copper wire (I used 10
guage and a 8 inch bronze plate) attached to every screw
that goes to all of the above mentioned and tied to the bonding plate. It is a lot of work, but at least if I ever
get struck, my chances of survival have been greatly improved. The only thing is when moored and the water is
"Hot" which means someone has a leak in there electrical
system you can get electrolysis real quick. Take your time and do a little wiring at a time. You will be glad you did,if you ever get struck!!!!
See ya, Ken
[image][/image]
Old 05-15-2007, 10:44 PM
Great stuff guys thanks!
I stumbled across a few more good links on this subject:
http://www.cdc.gov/nasd/docs/d000001...7/d000007.html
ftp://ftp.mdsg.umd.edu/Public/MDSG/lightning.pdf
http://www.marinelightning.com/science.htm
Old 05-17-2007, 10:47 AM
(I used 10
and tied to the bonding plate. The only thing is when moored and the water is
mr no bones
u neds to put #6 black grond wire on yer big toe then puts yer foot over da side whin you take a leak. u be safe and dunt get struck and no elicktolsis ya talkin abots
see ya sam
