Old 05-30-2007, 09:09 PM
ScottM ScottM is offline
Dieter Sprockets
Default Hydraulic Steering
What is the best way to refill a completely empty SeaStar hydraulic steering system? I replaced the hoses on my Seabird the other day and need to get it working again.
Old 05-30-2007, 09:31 PM
Finster Finster is offline
Default Re: Hydraulic Steering
Scott, fill up the reservoir and turn the wheel lock to lock a few times, loosen the nut on the helm, let the air out, and refill. Repeat this process many many wonderful times and you should be good to go.
But knowing a punk like you, you probably put the lines on backwards.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 05-30-2007, 09:41 PM
Scott
See if you can get your Dad to help. It's better with two people as one turns the wheel as the other loosens and tightens the bleeder valve. Use a small cup to catch the fluid under the bleeder valve and then re-use.
BTW: Keep mucho rags handy like Funster keeps in his cabin
Old 05-30-2007, 09:51 PM
His old system probably doesn't have a bleeder valve.
Surly Gomer Chuck would have this in his Sears catalog.
'76 23 SC CC I/O
Old 05-30-2007, 10:35 PM
Scott, I ran out to the barn and snapped these two photos
of my 1 man SeaStar purge system. PVC, barbed fittings,
5/16 hose all from local plumbing supply for under $20. Nylon fitting into helm filler plug, long hose from side of PVC tube to either side of hydraulic ram on motor.
Just hang tube above helm fill up tube, open bleeder turn wheel till no bubbles come out of ram. Reverse process for other direction of steering. It takes about 3 times turning wheel real slow to get all the air out. If you want more detailed photos, let me know. See ya Ken
BTW: I just replaced the ram seals before Anclote and a
quart of SeaStar fluid was almost $15
Old 05-30-2007, 10:37 PM
peterb peterb is offline
Nice snap shot Ken.
Here are SeaStar purging instructions
web page
Old 05-31-2007, 07:58 AM
Ken,
Is there anything you don't have in that barn of yours?
Old 05-31-2007, 08:31 AM
Ken, he didn't ask for a freak'n enema.
I don't think so...
'76 23 SC CC I/O
Old 05-31-2007, 09:45 AM
Yo Fungster,
That was remnants of my old bong from college days
I had to find some other use for it.
And Carla, thats why I had to build the barn because,
I just cannot throw anything away!!!!
See ya, Ken
Old 05-31-2007, 11:41 AM
Dieter Sprockets
...and yes it does have a bleeder valve, wise ass.
